Question about Frigidaire FRS26R4A Side by Side Refrigerator
But new filterin and no water comes out and vno ice
Water goes in but no water comes out check all lines there good
i have a
  • Anonymous Mar 05, 2009
    water comes out but trickles
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Kink line or clogged
Posted on Apr 02, 2009
Drain pan in whirlpool side by side refrigerator fills and overflows
do you have water hooked up to the machine?if so check the plastic lines that go to the water valve,i couldn't figure out why there was so much water in pan,all it is is when the fridge defrosts the heater comes on in freezer and melts the ice off of the evaporator coil and the water goes through the drain tube down near compressor to evaporate,i kept looking and stuck my hand in and there was a fine spray of water coming from a pinhole in one of the water lines,the owner never vacuumed
out the coil,so the machine was running hotter than normal,you can try shutting off the water valve that feeds the fridge and see if it stops overfilling,if it does you could have a hole in one of the lines,if there isn't any water hooked up to the fridge check the condenser coil to see if it's clogged with dust,this is how the heat escapes from the machine and the heat is what evaporates the water in the pan,also check the door gaskets,if they're torn or not sealing good warm air will get into the freezer causing ice buildup from warm and cold air mixing and forming ice,like i said the water that goes into the pan is from when the fridge goes into defrost,there's either more ice that's forming from an air leak or water is leaking from the filter line or one of the water lines.good luck with the detective work
Oct 01, 2017 | Whirlpool Refrigerators
Lg French door inside ice maker stops working but water flows out the back of the fridge where the water line gores in. Water line is fine and just had a new ice maker put in but it still does not produce...
Sounds like you have to have a leak in the water line somewhere. The water line goes to the top hinge in the door, so the water has to come from somewhere below that point or it would be collecting inside the door and leak out the front. A leak would prevent water from getting to the ice maker, or a leak at the valve could have this effect as well. Check the water valve that gets a call to send water to the ice maker.
Jul 07, 2014 | LG LFX25960ST Stainless Steel French Door...
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
Aug 03, 2017 | Refrigerators
Ice maker stopped making ice.
Check the line to be sure it is not frozen. If that is OK check the solenoid valve, that probably failed.
Good Luck,
Gilsh
Nov 26, 2009 | Refrigerators
Icemaker not getting water .it got water to the water dispenser but not going to the ice maker. put new filterin didn't help
THE WATER VALVE IS A TWO PART VALVE. THE ICE MAKER SIDE COULD BE OUT OR IN THE FREEZER WHERE THE WATER COMES OUT TO FILL THE TRAY COULD BE FROZEN BECAUSE OF A SLOW LEAK IN THE VALVE
Oct 28, 2009 | Refrigerators
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The water solinoid is not sending water to my ice tray
Had the same problem. As long as the ice machine is still moving, meaning its working but just no water is getting to the ice tray.  order part #2205762 valve, solenoid and change it out.  It is not hard to do if you pay attention to how you take the old one out.
Feb 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will not start, I have water coming out of the water disp, on front door but no water going to freeze
first check to see if the water line is frozen in the freezer where it goes into the maker. use a hair drier to thaw it and then you should be ok. also how cold is the freezer most ice machines need around -2 to make good ice.
Jan 01, 2009 | Refrigerators
Ice maker not getting water
It could be the water valve at rear.check water supply to valve,
if that's ok,you could change valve at rear
Nov 30, 2007 | Whirlpool ED2FHEXN Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
82 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
