Question about Lexmark C522n Laser Printer
Paper settings The printer is set to plain paper, when I print to printer lexmark c522 it has a message on printer put in transparency paper. I checked my settings and in input options the paper type is transparency. I change it to print to plain paper but when I close an application and open it back up transparency is in the type again. How do I set the settings to stay on plain paper?
    Scholar:
  • 136 Answers
When you change the settings do you hot then 'OK' button to see that the astix is next to it ? When changing settings make sure that you see that astrix next to your changes if not you will return to it's original setting. I alreaded assumed you knew how to access the menu's Make sure you set these setting by"OK" some printers like "Xerox" will make you hit the "Select" key
Posted on Mar 05, 2009
I have a Lexmark T630 printer and every time I go to print it beeps and says change tray 1. How to I get it to not beep while printing?
You will need to change your paper handling.
From the machine, go into the Menu-> then Paper Menu -> Change your paper size and type to your machine settings. Example if tray 1 is letter make sure it's set to letter and plain, then confirm each tray setting for each tray attached to the machine.
Also pull the tray(s) out completely and make sure the guides are set correctly. (The guides move so you can put legal, A4 etc.)
I've come across a lot of machines that the guides are off by a fraction which will prompt your machine to display the message you stated.
Nov 16, 2010 | Lexmark T630 Laser Printer
I have a Lexmark C522 When I print to it...the image that should be a full page prints really small on half of the page. How can I make it print what I send it?
this problem would indicate that the printer thinks the paper is smaller than it is. check the paper size settings on the drawer if the settings are right the replace the paper size pcb
Dec 03, 2009 | Lexmark C522n Laser Printer
When attempting to print, I get a :paper
The "reset to factory settings" should have worked.
What happened? What did not happen?
Did you power-off the unit after the reset,
including unplugging the unit from all AC power?
Sep 15, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Ink flakes off envelopes. No problems with sheets of laser paper.
High burnier:
Try these settings.
FUSER MODES
PLAIN
PREPRINTED
LETTERHEAD
TRANSPARENCY
PREPUNCHED
LABELS
BOND
RECYCLED
COLOR
CARDSTOCK>164 G/M2
ROUGH
[Paper Type]=
NORMAL
LOW
HIGH1
HIGH2
ENVELOPE
RESTORE MODES
Use this item to configures the fuser mode associated
with each media type.
Change the fuser mode only if you are experiencing
problems printing on certain types of media. After you
select a type of paper, you can select a fuser mode
that is available for that type. The available selections
might include some or all of the following modes:
NORMAL: Used for most types of paper.
HIGH 1: Used for rough paper.
LOW: Used for transparencies.
HIGH 2: Used for paper that has a special or rough
finish.
The default fuser mode is NORMAL for all print media
types except transparencies (LOW), and rough paper
(HIGH 1).
CAUTION
Do not change the fuser mode for transparencies.
Failure to use the LOW setting while printing
transparencies can result in permanent damage to
the printer and fuser. Always select Transparencies
as the Type in the printer driver and set the tray type
at the printer control panel to TRANSPARENCY.
When selected, RESTORE MODES resets the fuser mode
for each media type back to its default setting.
Hope this helps
May 24, 2009 | HP LaserJet 4300n Printer
Wrong Media loaded error - tranceparencies
hi!!! in that kind of problem maybe the paper sensor was defective and it can't detect the kind of paper you loaded to your printer.
Apr 18, 2009 | Lexmark C534N Printer
Error 34: Incorrect Media
Someone had set the paper type to "Transparency". I reset the paper type back to "Plain" and the printer started working again !
Jan 15, 2009 | Lexmark C522n Laser Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Paper Mismatch
Dig through the menus on the printer and make sure the paper type for the tray in question is set to plain. Sounds like someone set it to transperency and forgot to change it back.
Aug 29, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Lexmark C522n Laser Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
