Question about Sony Grand WEGA KDP-51WS550 51" Rear Projection HDTV
SONY KDP51WS550 NEEDS ITS D-BOARD REPAIRED OR REPLACED
I WOULD ATEMPT TO FIX HOW DO YOU IDENTIFY THE D- BOARD
  • 10,594 Answers
Below is an exploded view shows all boards location in KDF-51WS550
Hope this will help you to identify required D board.
Posted on Mar 04, 2009
How do i get power to my bravia ldl50r550a
Hi Laura,
To get power to your Bravia, the power supply board needs to be repaired or replaced. Sony guys generally do not repair it; they replace it. Try some other TV tech who may repair the power supply board.
May 28, 2015 | Sony Televison & Video
My Sony DSC H9 Failed to power up. I had it repaired under warranty by United Camera. I think they replaced the mother board or something.. less then 6 months later it did the same thing. One day it...
The problem is in the Systems Control Board "controls vital areas of the camera" or the battery needs to be replaced, if you have already checked the battery then the alternative is not good news.
Mar 30, 2011 | Sony Cyber-shot DSC-H9 Digital Camera
I have a Sony DCR SR40 that I replaced the screen on and in that process broke the fragile ribbon cable that goes between the display and into the camcorder. Can anyone identify that part and where I...
The damaged flexible ribbon cable that connects the LCD to the camera body and can be replaced fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Nov 16, 2010 | Sony Handycam DCR-SR40 Camcorder
My service tech said my d-board can't be replaced/repaired
He was wrong, Sony doesnt have them any longer, But you can get remanufactured ones that have the same warranty as the new ones used to. Check with www.tvrepairworld.com They should be able to get one.
Jan 05, 2010 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony KDP51WS550-LED light blinks 10 times
This is usually a problem on the high voltage board. When you first turn it on, the main board does it's P.O.S.T., then powers the HV board. You'll be hard pressed to find a replacement for it. You MIGHT find someone that can rebuild it, but for the money? Time for an open box special at you local electronics place.
Jul 02, 2017 | Gateway GTW-P42M303 42 in. Plasma...
SONY-LED BLINKS 10 TIMES
OK, 10 times is HV protection (High Voltage) and problem can be in D board and Q8013, Q8014 can be shorted along with R8051 open.
also IC8005 can be damaged.
All above parts on D board.
I would recommend to get related service manual for proper diagnose of problem in TV.
Good luck.
Dec 17, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Hi all, I had bought Sony CyberShot DSC-W55 and after making one series of pictures I had to charge a battery. After charging camera hadn't been used for around 1 week. When I was trying to take some...
Yes alot of the time on these camera they have a seperated flash circuit that can drain the battery even when it is off the flash circuit is not able to hold a charge and needs tobe replaced. it is quite easy to do. if you are going to atempt to fix it watch out for the compasitor it can knock your socks off lol I know it did mine.
Apr 01, 2008 | Cameras
Kp-57ws500 sony projection tv convergence problem
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Jan 22, 2008 | Sony KP-41T65 41" Rear Projection...
Sony tv
The problem you have is with the G1 board. The 17 volts is not supplied. Do you have a multimeter and know how to trouble shott following a service manual schematic? if not call a pro to assist you as this could be the G1 board, but to be sure, you will need to troubleshoot and check some voltages and follow circuit flow using a schematic diagram.If you can then let me know..
Oct 19, 2007 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony Grand WEGA KDP-51WS550 51" Rear Projection HDTV Logo
1,356 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
