TV green light comes on a few seconds and then cuts back off and never shows a picture. Too big to get into a car to have it fixed. can anyone help with this
-   Have the same thing going, did about a year ago unplugged a day, powered back and worked until last night. Tried unplugging it again and did not work this time. Might have to send it to have it repaired. -   badgolf
Sounds like the TV is in an error condition, and will not stay on (I know... duh).
The decision you need to make is whether or not the TV is worth calling an on-site TV company to diagnose and then perhaps fix the unit.
Best guess is:
$100 house call by "Atomic Television Fixers"
and $250-$400 for whatever control board is bad.
Again, how bad do you want to keep that television around...
Oh, by the way, that TV was probably delivered in one piece, but it will come apart in two major pieces for movement in tight places or removal from same. This procedure is described in the literature that was in the box when your television was delivered.
I have a Mitsubishi WS-65807 and I'm getting 1-2 code on the diagnostic. The TV won't power up....
(More)
I have a Mitsubishi WS-65807 and I'm getting 1-2 code on the diagnostic. The TV won't power up. When I try to turn it on the green led stays on for a few seconds, then goes off.
I'm working on a ws-65807 that had a convergence problem, but is now blowing fuse. I originally just...
(More)
I'm working on a ws-65807 that had a convergence problem, but is now blowing fuse. I originally just changed the IC's because of a convergence issue, but now the tv won't come on. The fuse is F9A05 and when I check for a code I get 2-2 or short protect. What should I be looking for that would cause this fuse to blow? The fuse is located on the power board where most Mitsubishi fuses are. I have never had bad IC's from the start, but might that be the case here? The green light on the tv would blink 3 times and the tv would turn on, but turn right back off. I replaced fuses F9A05 and F9A04 and seemed to fix the problem. Then I turned the tv off to put everything back together and it wouldn't turn on after that. So before I left the plan was to replace the fuse and not turn the tv off, but that only lasted 5 minutes. F9A05 is connected to diode D9A61 (where I think I should be seeing -24v, but don't know how to check that unless you need to test the tv under load) and pin 22 of power transformer T9A50. Please help me if you know what the problem is.
We have a Mitsubishi WS-65807 rear projection television that stopped working all of the sudden....
(More)
We have a Mitsubishi WS-65807 rear projection television that stopped working all of the sudden. There is no picture (no blue screens, no menus, just black) and no sound. The green light on the front of the set labeled "timer" comes on and will not go off. I would really appreciate any suggestions--I don't want to overreact and replace the TV if this might be a simple problem. Thanks so much.
we have a mitsubishi HD 1080 series rear projection tv made in fall of 2000. the DVD player thru...
(More)
we have a mitsubishi HD 1080 series rear projection tv made in fall of 2000. the DVD player thru component video works fine on either 1 of 2 component connections. Every other connected device including games, cable tv, and Roku (thru component or red white sound yellow video) work intermitently, then screen goes blank with about an inch of screen visible at top only. struggling with what to do - I opened back, no obvious loose connections. Ideas? I certainly would appreciate specific direction to a fix that saves me from bringing the huge tv into the repair shop - is there an adjustment to make? is there a likely component or board that is at fault here? Thanks
I want to know how to fix my WS-65807 tv, but can't seem to figure out what to change and where it...
(More)
I want to know how to fix my WS-65807 tv, but can't seem to figure out what to change and where it is on the board. I really appreciate any help possible, Thanks
