Question about Intel D945GCZLR LGA775 1066MHz FSB DDR2 SATA PCIE Audio BTX Desktop Board Bulk of 10 -BLKD945GCZLR (NEWITEM62564019) Motherboard
I have an Intel D945GCZ mainboard At startup I
I have an Intel D945GCZ mainboard At startup I get 3 long peeps with no startup. It was working fine. I tried changing RAM with no luck.I also disconnected everything off of the main board
    Scholar:
  • 56 Answers
This is a diagnostic beep code which is designed to tell you something is amiss with your system. The code patterns of short and long beeps are not fully standardized, so it depends on who manufactured the BIOS for your motherboard. Generally three long beeps indicates an issue with the base memory - the first 64K. Try putting your RAM sticks in one at a time and powering up the system. Make certain they are oriented correctly (note the notch) and firmly seated in the socket.
Posted on Mar 04, 2009
Trying to find heatsink unit to be able to use the board
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCZ
Your mainboard is using the LGA 775 socket.
The heatsink fan looks like this:
The fan can still be bought in a computer store, online shop or a repair shop.
I will recommend to but a better fan, like the brand northq, because the standard fan is difficult to mount correctly on the mainboard.
Remember to add a bit of cooling paste on the cpu, before you mount the fan.
Good luck
Sep 17, 2013 | Intel D945GCZ Motherboard
I have a mainboard D945GCZ and i have unknown PCI Device in Hardware Manager console
Take a look at the boards that are plugged into the PCI slits inside the case, these are usually cream plastic slots about 9cm long. See which of the ones you have installed are listed and then install the missing one. Hope this helps. If you are running XP or Vista you only need to "right click" on the item and select "Update Driver". It should find the correct driver automatically. Good luck.
Nov 24, 2010 | Intel D945GCZ Motherboard
My software audia is not working it doesnt have sound
Visit ths site and download the required drivers.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCZ
Nov 07, 2010 | Intel D945GCZ Motherboard
My realteck driver (sound driver) is not working properly.then please give me suggestionwhat sould I do. some time it is working properly but sometime doesn
visit http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCZ and update the driver.
May 21, 2010 | Intel D945GCZ Motherboard
Intel d945gcz mobo cannot setup Winxp pro, (reboots)
Have you tried going into BIOS Setup, and in Boot Options, change the first boot device to CDROM?
Do you have the Motherboard Manual for your Intel D945GCZ?
This is Intel Support, and the download page for the Motherboard Manual.
It is a PDF file.
http://www.intel.com/support/motherboards/desktop/d945gcz/sb/CS-020793.htm
Sep 26, 2009 | Intel D945GCZ Motherboard
PC 2700 DIMM emachines memory upgrade probems
1. There is a problem with your new RAM even though it supports up to 4 GB it doesn't mean that 1 GB of RAM is compatible. It's possible that the 1 GB DDR2 that you have installed is not supported by the system bus of the motherboard and won't make it through startup because of compatibility issues.
2. Try getting RAM from this dealer because its compatible with your motherboard and supports the system bus http://www.pcmemorystore.com/Intel-Intel_Motherboards-D945GCZ-ram.htm
Apr 05, 2009 | Intel D945GCZ Motherboard
Need Manual
Go to www.intel.com. Click on support link. Lookup your specific board model #. You will be able to download the manual from there free of charge. Hope this helps.
Mar 23, 2009 | Intel D945GCZ Motherboard
Computers & Internet Logo
128 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
