Question about Hoshizaki F-1001M Flake Ice Maker
E4 keeps comeing up on my hoshizaki ice maker
  • courtneypree Mar 04, 2009
    e4 keeps comeing up on desplay and stops makeing ice
    e4 keeps comeing up on my hoshizaki ice maker fm-251 afe 50 hz
    Problem Solver:
  • 16 Answers
Please call us at 800-233-1940 or give me model and serial of machine.
Posted on Jun 19, 2009
Hoshizaki km151bah ice machine not making cubes. ice is coming out in one big sheet. Why?
The depth setting on the evaporator cube setting may be set too thick making the cubes stick together. Adjust it to make smaller cubes.
Feb 28, 2015 | Hoshizaki KM-151BAH 121 Pound...
Hoshizaki KM-630MAB
Check your refrigerant pressures during harvest. The board is picking up a fault. You could have a thermister problem on the suction line.
Jun 26, 2014 | Hoshizaki Kitchen Appliances - Others
The ice maker make too much ice
Too much ice is usually and indication that the bin thermostat is not functioning correctly. It has either come out of it's holder, is not calibrated properly, or has lost it function and needs replacing. The thermostat "Kills" power to the control board when Ice comes in contact with it and shuts the machine down. Hoshizaki says it should happen within 6-10 seconds of ice contact after the end of a harvest cycle. I would start there first.
Apr 09, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KML-450MAH ice maker wont start after clean up
If you did a cleaning cycle and used the bypass valve to clean between the evap plates, look for the micro switch on the bypass valve to be bad. It is a small switch attached to the by pass and keeps the compressor off during the cleaning process. I'd start there.
Jul 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
New install
The machine is suppose to start filling, then after 45 seconds or so turn on in the harvest mode then when the temp gets where the sensor says its suppose to be it starts to freeze.
If water keeps coming out the over flow the water valve may be stuck open and this is why you can't make ice its letting in warm water all the time. Try turning the water off to it and see if it freezes a batch. If so replace the water inlet valve or remove and clean it
Dec 12, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Hoshizaki F-1001M Flake Ice Maker Logo
121 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
