Question about Pentair 1.0 Hp Whisperflo Pump
Don't know how to open Pentair cartridge filter clamp
Do I have to unscrew the clamp?
Can't find any instructions.
Thanks!!!
  • 125 Answers
Yes, unthread the clamp to loosen it then the lid will be able to be removed.
Posted on Mar 04, 2009
How to replace sand in a jandy st24-t
there is a nice big o ring between the valve and the filter body. chances are that it is dried out and holding fast. it will take some muscle to separate the two but it can be done. be prepared to change that o ring on re-assembly.
here is a breakout plan to help you visualize
ST18 ST 20 ST24
Sep 01, 2014 | Pool & Spa
Pool plumbing diagram
You may experience a little pressure loss, but if the catridge fliter housing has a 1 1/2 input you should be fine.
Jul 17, 2014 | Pentair Clean and Clear Cartridge Filter...
How do you change the center core for pentair 160317 cc150
If you are talking about the cartridge, You first have to make sure filter is off. turn and open the pressure gauge to release pressure. Now If you can reach the bottom drain plug, unscrew it. If you can't that's okay. Your filter has a center belt - ring, and it has two push tabs. Push up and turn it counterclockwise. Take that off and you should be able to pull out lid. If you have a hard time taking off the lid, get a flat head screw driver and pried it open.. Good luck.
Mar 15, 2014 | Pentair Clean and Clear 150 Sq Ft...
How to backwash a pool with a pentair intelliflo vs + svrs pump and pentair cartridge filter
if you want to backwash put in service mode after then put back online you cannot backwash a cartridge filter
Sep 02, 2013 | Pentair Pool & Spa
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
How do I turn on my Pentair Pool Filter. Brand new, I don't know how to turn it on?
Go to the Pentair website and you should find a manual you can download for free.
Aug 20, 2011 | Pentair Intellitouch Pool or Spa...
I tried to clean my Pentair CC-150 pool filter but when I tried to lift the cartridge up and out of the filter shell it wouldn't budge. Any suggestions? Thank's Greg Hamlin
This is a common problem with cartridge pool filters, but it should come out with a little elbow grease. Try gently twisting it back and forth like a steering wheel using firm even pressure.
Aug 16, 2010 | Pentair Clean & Clear Filter and Dynamo...
Pentair Quad DE system was installed without multiport valve
This is a DE (Diatomaceous earth) IT doesn't have sand and doesn't backwash. You use the bump handle (with pump off and valves closed and vent open and drain dirty water/earth out) Here is a link to the manual for your filter If isn't the exact model they are all on their web site: http://www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jul 20, 2010 | Hayward EC-40 DE Pool Filter with pump
Do i have the right size pump for my 10,000 +/- inground pool
Bruce,
the cartridge element system you have is designed to be used for at least two seasons before needing to replace the elements. You are correct thinking that the pressure going through the filter is causing the problems with the cleaner.
if you take the elements out of the filter and see if cleaner works that will show you whether or not it is time to change the filter elements. That filter is very expensive to replace. cheaper to just change the elements.
Mar 01, 2009 | Pentair 1.0 Hp Whisperflo Pump
Im having trouble opening the sring clamp on the hayward pool fil
once the ring is unthreaded it may need a good hard tug to open the filter lid.
Feb 01, 2009 | Hayward Easy Clear 40 Sq Ft Cartridge Pool...
Pentair 1.0 Hp Whisperflo Pump Logo
116 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
