Question about Kenmore 62622 Electric Dryer
Kenmore Dryer won't heat
I have a Kenmore electric dryer that suddenly went ''poof'' (like when a light bulb that goes out). It threw the breaker. I reset the breaker and the dryer started. I thought that was all there was to it, but now it won't heat the air. I checked continuity of the fuse, both thermostats, and the heating element. All checked out. I did not check the continuity with the wires disconnected, but got no continuity in the temp switch, so I replaced it to no avail. (still no heat) I read in the repair manual to disconnect the wires from the posts to check each component. The thermostat that has 4 wires checked out on two of the terminals, but not the two others. I then replaced it and still no heat... I hate to call a repair guy out at this point. Any suggestions?( The model # is 66722691)
  • 979 Answers
There is a thermal overload switch that is located under the top of the dryer. It probably is bad. You can find it close or next to the drum. Bypass it and see if it comes on and if it does, then replace it. This is probably where it is since you have apparently checked out everything else.
Posted on Mar 04, 2009
  • Kenmore Master
  • 3,361 Answers
Unplug the dryer.
Always remove wires to check continuity or Ohms on any part.
Remove the terminal cover where the cord connects and check all wires.
Also, check them to ground on the chassis. The only one that should read continuity is the ground wire.
After removing the wires from the heater check the heater terminals to the heat canister.
If it reads continuity it is bad.
Pay special attention to the relay on the top side of the heat canister.
4 Suggested Answers
  • 583 Answers
SOURCE: I have a Kenmore electric dryer that suddenly went
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Posted on Mar 03, 2009
  • 1122 Answers
did you check the main fuse on the blower box with the wires off?also check the heater box fuse(top)and the high temp thermostat on heater box(bottom)with the wires off-mike
kachbibi1
  • 979 Answers
rmtg
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Kenmore gas dryoer model #11073912100 not getting hot, all vents cleaned out, still won't work. could it be pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Sep 11, 2011 | Kenmore 74112 Gas Dryer
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
The Pilot light oa a Kenmore Gas Dryer went out .How can I re-light it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 27, 2010 | Kenmore 72062 Gas Dryer
My Kenmore auto dry I no longer gets hot. I assume the pilot light went out. How do I re-light the pilot?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 27, 2010 | Dryers
I have a Kenmore electric drier # 110.60912990 It runs fine, but no hot air. What should I check. I checked the outside vent and air is coming out. I check the circut breaker and it is fine.
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 03, 2010 | Kenmore 64942 Electric Dryer
I have a Kenmore electric dryer that suddenly went ''poof'' (like when a light bulb that goes out). It threw the breaker. I reset the breaker and the dryer started. I thought that was all there was to it,...
Mar 03, 2009 | Kenmore 62622 Electric Dryer
Mar 03, 2009 | Kenmore Dryers
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Kenmore 62622 Electric Dryer Logo
241 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
