I need a power supply model aep028 or the ic chip ice3b2565
I volunteer to help.
Tell me: why do you need the model? simulation? system-level simulation?what simulation platform you have?
Posted on May 21, 2009
Need power supply schematic , Model AEP028
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 02, 2016 | Televison & Video
Realistic 32 1210
I assume you checked & tested the fuse? so you have power into the supply but not out.
"can" capacitors have a triangular wedge in the top of them. If the top is swollen and or has a smudge discoloration it has been over stressed or is worn out.
Some hand held testers have a diode check on them. So you can test the diode
The IC chip may be the problem and if it is in a chip plug your in luck you can re & re it easy . If not, that will be a tough job and beyond my know how
Oct 05, 2013 | Audio Players & Recorders
Vizio lcd tv will not turn on but the
This is a very common issue with this model TV. The problem is caused by the power supply controller chip. This is a small 3 pin chip on the video logic board. When this chip fails the TV video board never gets the signal to turn on and display a picture. Here is a picture of the video controller board from the TV with the power supply controller chip circled, and here is a link to order the IC chip. Open the back of the TV and look at the little chip, you should be able to see that it is burnt. Replacing the chip should bring the TV back to life.
Jul 19, 2012 | Vizio L32 32 in. LCD HDTV
5130 no service
hello all you need to do to fix a dropping signal like it shows a signal when freshly powering up the phone then after a few second the signal lost. In this problem you may replace the PA IC. Check first the supply voltage of that said IC before replacing it. For a total No network signal shown on the device, check all the supply voltages across on its corresponding RF chips. if all the voltage readings were all okay. reply both PA and the RF chip alternaterly.
Apr 16, 2011 | Health & Beauty
BPL i short model television it's using La76931 ic problem is single horizandal line i cahange la78040 vertical ic but not cure.
Did you check if 24v supply is coming to the chip ( through a fusable 10 ohm resistor ) ?.Look for dry solder on the sync chip ( 24 pin or 40 pin IC ).
Mar 11, 2011 | Televison & Video
Combo dead. no display ac present on power supply fuse. fuse ok.
IC processor chip probably deadif you can't access either unit you probably need to get a new one, replacing the IC Chip usuallt costs more than the Combo itself
Jan 03, 2011 | Grundig GR-1000 DVD Player/VCR
Purchased a 32"Protron FLat Screen from and the power light comes on but no picture; now it wont' come on at all.
Your partial resonance power supply IC chip with IGBT switch is bad. On your model of TV it will cheaper to replace the whole power supply module
Aug 20, 2010 | Protron PLTV-32 Television
No power to box ic is blown in power psu where can i get replacement as the top has come of chip its the ic1 or 4 chip but cant read anything from chip as no top  need to get it repaired
We can probably look up the part numbers, but we'd need the make and model of the unit. Can you please update this with that info? Also, is the IC marked on the board IC1 or IC4? Hopefully you can also indicate which IC is smoked. When we look this up, we will provide other parts that need to be checked. It is unusual for an IC in the power supply to be the only failed part.
Please update this with the above info.
Oct 23, 2009 | Audio Players & Recorders
Earthquake ph-d2
The PWM IC is an SG3525. Which IC are you calling the protection IC?
Nov 02, 2007 | Earthquake Sound PH-D2 Car Audio Amplifier
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
