Question about OKI MICROLINE 590 Matrix Printer
Printing gibberish then feeding several lines, printing gibberish
Our Oki 590 wasn't lining text up properly on our auto-feed forms so we did a lot of trouble shooting. it would never adjust so it was unplugged and disconnected for a day. after more trouble shooting it won't do anything but print a line of gibberish such as question marks and feeds several lines, almost a page. it just continues this and we have tried swapping computers, cables, drivers. we've plugged everything directly into a wall instead of our power surge protector. we've had an IT guy come in and tried everything we can think of. we switched another printer into this spot and it did the same thing. it's like we have gremlins!! what can we do?
  • jmoore915 Mar 05, 2009
    yes, i probably should've been more specific. in trouble shooting we tried every setting in the menu and nothing helped. we now think a surge shocked it or something.
    Problem Solver:
  • 5 Answers
If text did not line up as planned, your TOF ( top of forms adjustment ) isn't correct. Just correct it using the button on the panel. If after printing 1 page or so and then it begins to go out of place, most probably you hv set the page lenght incorrectly. To correct, enter the MENU on the panel and set the correct page length.
Lastly if printing garbage, most probably you have selected the wrong emulation on the MENU. Correct by entering MENU mode ( press ' SHIFT+MENU ' button together ) and select the correct emulation.
Hope this helps.
KM HOO
Posted on Mar 05, 2009
  • firstfix Mar 06, 2009
    Ok maybe you should check this next. If you hv tried connecting with another printer and get the smae results, most probably the problem is with the PC parallel port ( If you are connecting to a parallel port ). The next to check is if the PC driver matches that of the printer ( if Epson LQ2550 driver on PC, printer emulation should also be set to epson ) or else it will print garbage and feed an empty page. If both end driver matches, and windows test page prints ok then there is nothing wrong with the printer .
    Bst luck.
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
Escape sequence for reverse feed
Manual
Page 73 has two commands that may be of interest
Form Length
And
Line Feed, Execute, Reverse
Hope this helps
Dec 17, 2007 | OKI MICROLINE 5590 Matrix Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Form won't line up
your feed assembly needs to be replaced, the gears wear out on them and the next thing you know, it's moving on it's own.
t
Nov 17, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
No puedo configurar el top form de la impresora
aprendizaje hablar español :)
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
No he intentado traducir las instrucciones mientras que puede causar la confusión.
Sep 10, 2008 | Epson DFX-9000 Matrix Printer
Oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
Keep me posted if you have inquiries, thanks!
Jun 18, 2008 | Epson DFX-9000 Matrix Printer
Printer is not aligning paper properly.
Please try the following to resolved that issue:
Jun 10, 2008 | Epson DFX-9000 Matrix Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE  590 Matrix Printer Logo
876 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
