Question about Ricoh Office Equipment & Supplies
I need the error codes for a Ricoh FT4222 analog copier - in particular ''E5'' when the machine is turned on.
You need to press the "*" (star) key to read the last 2 numbers, however all "5xx" are fuser errors. The fuser is not coming on, or not reaching full temp. It is either a blown fuse, lamp, or thermistor. The part(s) need to be replaced before the code can be reset, and a service tech is required to perform this in "service mode"
Posted on Mar 05, 2009
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
How to reset error E5 on nashua coprier
theres no e5 on aficio 450must be sc542/546 problem with heater try to reset code press yellow
button then 1 0 7 then press red button keep the red button held down 4 secounds then select
copy 1 turn copier off then switch back on
Nov 11, 2010 | Ricoh Aficio 450 Copier
HOW WILL I SOLVE PROBLEM OF E5 ERROR MESSAGE IN RICOH 4018 AND E11 ERROR MESSAGE IN RICOH 4622 PHOTOCOPIER
e 5** fuser related temperature over/under
e1** optics related
both need service engineer
Oct 04, 2010 | Ricoh Office Equipment & Supplies
ERROR E-5
E5 error always denotes a failure in the fuser unit for ricoh machines. please check all components and repair or replace damaged , blown thermal fuses, heating lamps or thermistors. then perform simulation 5-810 to reset error.
Jul 29, 2010 | Ricoh Office Equipment & Supplies
Ricoh ft5832 code e5 47
E547 is a level A code (need to do a fuser SP reset, copier is inop) the fuser lamp continuosly stays on. Probably a shorted triac or fuser board problem.
Apr 12, 2010 | Ricoh FT5832 Copier
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
Reset the error code e-5 on a ricoh ft4522
There is no need to use dip switches to reset this error code.Providing that the thermistors are good and they have been installed correctly,here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Aficio 450 Copier
Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Mar 11, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
135 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
