Question about E-Machines E17T 17" Flat Panel LCD Monitor
Monitor Flicker I recently got a new video card and while it was installed at my grandparents house, and worked there I bring it home to my house, the computer i mean, and now my monitor doesnt work, the on button will flash continously on the monitor and nothing else happens Thanks
  • 52 Answers
Hello, my name is Chris. This is a really simple fix. Please make sure that your VGA card (video card) is pushed in on the motherboard. Even if it's a PCI Video Card. Still check. And make sure it is screwed in as well. If it's none of the above, than your motherboard is fried.
Posted on Mar 04, 2009
Beep codes on dell xps one 2010
If I understand your issue, it sounds like the display works fine until it loads Windows, and then it has the error? It sounds to me like the video card drivers are crashing. This may be the case if you have recently updated them, or installed a new video card. I would recommend getting the latest drivers from the manufacturer's website on a CD, SD card, or USB drive, and then boot your computer in safe mode. Once in safe mode, install the new drivers, and see if that will help. You could also try using your onboard (integrated) video card if your motherboard has one. This could help rule out if the monitor is at fault. Just make sure your BIOS has the integrated card as a secondary video device if it the (I'm assuming PCIex16) peripheral card isn't found.
Oct 06, 2012 | Dell XPS One All-in-One TV Desktop with...
My screen has recently begin to flicker intermittently.
Try hooking the monitor up to another computer and see if you experience the same problem. If you don't have another computer, attempt to hook up another monitor to the same computer and see if you experience the same problem. If the problem sticks with this and only this monitor, then more than likely you have some bad capacitors in the monitor, which may be replaceable but require a bit of work to fix. Else you may be looking at a new monitor if this isn't under warranty any longer.
If the problem happens with another monitor on this same computer however, it sounds like you have some video card issues and you probably want to look into getting a new one of those.
Mar 21, 2011 | Gateway FPD1975W 19" LCD Monitor
The screen does not sweech on.
If you turn the monitor on, is it getting power? Try hitting the menu button. If it is not getting power, check to make sure that its' plugged in and that the receptacle is in working order. If it is getting power, check to see if the cables are hooked properly to the computer. If you have another computer in the house, try hooking the monitor to another computer to rule out a problem with your computers' VGA card. if you determine that the monitor is okay, it's probably your video card. You can purchase a new video card on the internet, shipped to your home, for less than 20 bucks. installing it takes about 5 minutes as well.
Jan 25, 2011 | LG L1915S 19" LCD Monitor
Video on my HP Pavilion a1540n is broken
Yes you put in the video card and the default is lowest resolution and is usable without a driver, install driver then reboot and you have your new video card to set up the way you want.
May 15, 2010 | HP Pavilion a1540n PC Desktop
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running...
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Oct 24, 2009 | Acer AL1916W 19" LCD Monitor
PC is not working. Monitor message says 'monitor
Check to make sure that you have it plug all the way in to the video card. Also make sure that the video card itself is seated or pushed in good.
You could possibly need a new video card or the pins on the plug coming from the monitor could be bent.
Oct 13, 2009 | Computers & Internet
Screen flicker
if you test it with another monitor did it flicker? if not your monitor has a problem. if it still flicker the problem will be pointed to the video card. try to replace the video card.
Aug 03, 2008 | Acer Aspire L100 PC Desktop
Moniter flicker
Any monitor flickers at 60 hertz. The usual reason for being unable to use faster refresh frequencies is that the correct video card driver and/or monitor driver are not installed. Another possibility is that the resolution is set too high. Assuming Windows XP, right click on the background, choose "properties", settings tab, advanced button. Check to make sure your video card is named - the monitor is not as important but would certainly be helpful. If not, did out the CD's that came with them or download drivers from the manufacturer's website. On the other possibility, on the adapter tab, there ought to be a "list all modes" button so you can choose resolution and refresh rate at the same time. Your LCD monitor will be fussy about the resolution, so you may need several tries to get something that looks good and doesn't flicker.
Sep 12, 2007 | Acer APFV MT (APFVUP5152) PC Desktop
I NEED HELP
The problem resides with your monitor or your video card. To easily find out, get a family member or a neighbor to bring over their LCD monitor, then check the display. An LCD is the easiest to carry and easiest to position on a busy desk. If the display is normal on the LCD monitor, then your "other" monitor is defective, and vice versa. (Please ensure the monitors are at least turned OFF before you switch them, not necessary to turn off the computer) ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | MSI G4 MX440 (64 MB) Graphic Card
E-Machines E17T 17" Flat Panel LCD Monitor Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
