Question about Motorola Mobility RAZR V3
Meade autostar hand unit fails after 2 seconds changed hand units
Reverse polarity applied to unit then this problem began. cannot find a fuse on the autostar board.
    Problem Solver:
  • 14 Answers
Does the Autostar start to come on then fail, ie you get the bleep and initial display, then nothing more? If so, it sounds like it is not completely blown.
I wonder if you need to reload the firmware? You can do this if you have a serial cable to connect it to a PC. To put the Autostar into "Bootstrap loader" mode, power off, then hold down the top left and bottom right buttons on the Autostar whilst you turn the power on (needs at least 3 hands!). The screen displays a different message and waits for new firmware to arrive up the serial lead. Look on Mike Weasner's site www.weasner.com/etx for full instructions.
Posted on Aug 15, 2009
My question is, I have a Meade Autostar #494 How do I see through the lenses?
The 494 is the HAND CONTROLLER NUMBER--- not the telescope. What Meade telescope do you own??
Aug 20, 2011 | Meade 494 AutoStar Telescope Control Unit...
Telescope control unit AUTOSTART failure
Unplug telescope from powe. Then reinstall software, it should fix it
Aug 04, 2008 | Meade 494 AutoStar Telescope Control Unit...
Message...Proc. trap 2 what does it mean ?
It means the firmware is corrupted.
It may be possible to reset it from software.
Try and reload the Autostar firmware from a PC.
(Download the updater application from Meade's website.
http://www.weasner.com/etx/autostar_info
http://www.meade.com/support/index.html
Feb 02, 2011 | Meade 494 AutoStar Telescope Control Unit...
Lz200gps doesn't boot and I can't communicate via com1
Before you panic, try a new hand controller cable. You can buy these from Meade or for a better one from www.scopestuff.com
"Autostar II: if you need to use Safe Mode to recover from a disaster,
turn on the telescope, and key 999 before it says "Initializing"
The Autostar will say "Flash Load Ready"... now go start the ASU.
Read this page all the way through--
http://www.weasner.com/etx/autostar/guide-asu3x.html
Jun 02, 2010 | Meade LX200GPS Telescope
Nothing seems to work on my LX90
You may need to purchase a new hand unit.
go to meade.com for purchase.
May 15, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
Display on the autostar does not light up. The batteries are all changed, the power light comes on on the tripod, but the handset is dead.
Could be a cable problem. REVERSE the cable ends and try it again. Make sure the scope is always turned OFF before you plug or unplug a cable.
If this does not work then try a new cable. Meade sells these, or you can order a nice one from www.scopestuff.com . Not very expensive.
If after installing a NEW cable it still does not light up then time to buy another hand controller.
http://scopestuff.com/
Oct 31, 2009 | Meade 494 AutoStar Telescope Control Unit...
You damaged the circuits inside the hand controller-- unless you are an electronics whiz these cannot be repaired.
However you can find them for sale directly from Meade and on Ebay (used) usually for about $80.
Mar 04, 2009 | Meade 494 AutoStar Telescope Control Unit...
Meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Apr 22, 2008 | Optics
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
