Question about Canon imageCLASS MF6550 All-In-One Laser Printer
I have a Canon MF6550 that stopped working after someone was zapped by static electricity while pressing the print button. We can receive faxes but cannot do anything else. None of the buttons work or light up on the panel. Can this be fixed or should we just replace it. It is not yet a year old.
  • townofjoliet Mar 05, 2009
    Apparently the warranty does not cover electrical type incidents.
    Scholar:
  • 136 Answers
Contact Canon- If it's under 1 years old it's should be under warranty, Chances are you blow out the power supply fuse for this copier, the fax feature is Seperate Section.
Yup call Canon you should still be under Warranty.
Do to Fixya.com rules I am not sure if I can give you the phone number plus I am not sure if your in the US or elsewhere.
Posted on Mar 05, 2009
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
How to receive fax by Canon Pixma MX328 in Telephone Priority mode? What to do when the person on phone asks to give fax-tone to send the fax
If a phone extension is attached to your printer, and when someone is trying to send a fax to you.....just answer the phone. then on the printer press the Black button to start receiving documents in black printing or press the Color button to start receiving documents in colored printing.
If your are not using a phone, just press the Black or Color button when you hear the printer is ringing.
Aug 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
Duplexing
Someone has changed the settings on the unit. If you go into Additional Functions press set on Common Settings scroll to Paper feed switch and set it for Speed Priority not Print Side for each category. The only other thing that would cause this is that each individual setting was set for 2-sided in which case you would want to check Additional Functions and each one Copy Settings, Printer Settings and Fax settings.
Nov 24, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Canon Image CLASS MF6550 not printing
hi kim
you have a stuck shutter in front of laser unit very common problem
charlie
Aug 19, 2008 | Office Equipment & Supplies
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MF6550
Try to press te System Monitor Button and scroll using the > to Print Status. If there is a print job in there press ok the < to cancel the print job. You may want to check the other status windows in case it is a Fax or Copy job instead of a print job.
Apr 18, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
After static shock, keypad on fax machine is not working...everything else ok
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
Nov 30, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
103 people viewed this question
old marine
old marine
