Question about GE Dishwashers
Dishwasher will not drain there is a bunch of water in the bottom. Tried running it through the cycle to make it drain out but still nothing just water in the bottom. Checked the sink and garbarge disposal to see if anything was blocking it or clogging it up but got nothing. Any suggestions?
  • shanahnon Mar 04, 2009
    Thanks, also there is a humming noise when trying to drain out the water? Just wondering if it would be better to try to replace the part or just get a new dishwasher?
  • GE Master
  • 3,361 Answers
Most likely a bad drain valve solenoid.
It is attached to the side of the motor.
The GE solenoids tend to burn out.
Posted on Mar 04, 2009
  • steve
    steve Mar 04, 2009
    Your GE dishwasher motor is stuck.
    Turn the power off to the DW.
    Remove the toe kick panel.
    Take a flat blade screwdriver and turn the motor armature counter clockwise until it breaks free.
    Use 2 screwdrivers, turn with one and hold it in place with the other and re-grip. Then turn it again until you feel it move freely.
    If it does not break loose, replace the motor and pump or the dishwasher.
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Water left in bottom of dishwasher after cleaning
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
May 23, 2009 | Dishwashers
Water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Feb 16, 2009 | General Electric Adora GHDA670N Built-in...
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher confused
i suspect this is nothing to do with switching off during the cycle.
take the bottom plate off and check if there is water leaked into the bottom pan. alternatively, if you can, tilt the machine back to 45deg and see if water runs out.
most machines have a float switch in the base so that if water leaks, all that will happen is that the drain pump runs and i think this is what you are hearing
Aug 07, 2008 | Dishwashers
Whirlpool built in dishwasher. not aware of model number
Putting vinegar in the bottom of the dishwasher is not going to help because it has nothing to do with the FILL cycle. The bottom (or sump) actually is used during the WASH and DRAIN cycles. I would check the fill port where the water inlet hose goes into the side of the wash tub. You will need to pull the unit out and locate the inlet hose on the SIDE of the dishwasher. The hose should be a black rubber hose located on the left-hand side of the machine. I had a very similar problem that turned out to be calcium deposits clogging the fill port BEFORE it got to the fill valve. With the unit turned off, I removed the rubber hose and used a small screwdriver to poke straight down into the fill port and break up a bunch of calcium. The unit worked fine after that. It is normal for some dishwasher models to drain if they do not detect enough fill water, or if they detect a leak. Usually when the fill port becomes restricted or clogged you will find puddles of water forming under the dishwasher. You might want to remove the bottom panel and check for leaks as well (if you haven't done so already). If you check the fill port and it is clear, the fill valve could be a possibility as well. However, you mentioned you could hear water running which leads me to believe that you have a simple clog somewhere...but, the valve could have accumulated some deposits as well. Check the fill hose and let me know. Good luck and I hope this helps you. PS Another common mistake people make is to put drain cleaner in their dishwashers. This can damage the pump and chopper assembly. Not to mention, it could be harsh on the some of the rubber seals. Not a good idea.
Jul 30, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
63 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
