Question about Solar Touch Plate Four Switch Low Voltage 5004, 2 Gang Ivory
1 of 6 switches on the panel has started malfunctioning. Does not switch. Was off, now stays on.
  • 979 Answers
You probably have the wires that are touching each other. The switch is bad of course. Just replace it and it should be O.K.
Posted on Mar 04, 2009
Why does my Telefunken Vegas HD Plasma tv keep switching on and off by it self?
take it in for a proper diagnosis but it appears that you have a component that is malfunctioning or over heating , probably in the power supply
Jul 08, 2016 | Televison & Video
Why does fuel pump want stay on in chevy cavalier 1999
...if it wants to stay on after turning the engine off, it is probably a malfunctioning fuel pump relay.
...if it won't stay on after starting the engine, it is probably a bad oil pressure switch. Not sure what you meant.
Nov 05, 2015 | Cars & Trucks
When I start our mistubishi canter, 3c13d . Year 2006,,,the lights come on the front and won't knock of. We took relays out and they still stay on, could it be the main light switch , any ideas
It's got to be in the switch. It should have a position for automatic on when started and timed to go off when engine is off. If the lights don't go off when you turn the light switch in off position, then it would have to be the switch malfunctioning.
Nov 30, 2014 | Cars & Trucks
Front panel switch malfunction
chek buttons if possible can remove buttons cable
Sep 01, 2012 | Samsung SyncMaster 740N 17" LCD Monitor
QCA Spa Contol Panel Issues
Flow issues can be frustrating, check each of the following
1. Low GPM.
2. Low Water Level.
3. Blocked Suction Fitting.
4. Blocked Skimmer.
5. Dirty Filter. (Try run system w/o Filter)
6. Too Many Closed Jets.
7. Closed Slice Valve.
8. Heat Related Pump Not Running.
9. Heat Related Pump Not Primed.
10. Malfunctioning Impeller.
11. Incorrect Heat Related Pump.
12. Circ System Misconfigured.
13. Sensor Malfunction.
If none of those help try this. There is a link to s Balboa site for service tech diagnostic help. There are step by step instructions for diagnostics.
Jan 23, 2012 | Pool & Spa
Dryer light switch malfunction
your door switch sounds faulty
Jun 12, 2009 | Dryers
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Park lamps stay on
Hi! Check the switch, it could be malfunctioning.
Dec 30, 2008 | 2007 Hyundai Sonata Limited Sedan
Interior Lights malfunction
trace to switch (can't remember name, but it has to do with the timing of lights) and clean contactpoints. if not replace switch>
Nov 21, 2008 | 1998 Plymouth Voyager
Solar Touch Plate Four Switch Low Voltage 5004, 2 Gang Ivory Logo
75 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
