Question about Thermador Professional Series PO301 Stainless Steel Single Oven
Thermador single convection SC301TP LED light panel is inoperative. Tried changing capacitors on assembly. Did not work.
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Thermador single convection oven, SC301TP has inop
Welcome to FixYa.
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available.
You can find these "display kits" at "repairclinic.com" for around $275USD and includes what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Posted on Dec 29, 2010
Thermador oven control panel light is very dim
FixYourBoard.com fixes this problem, and they back their work with a two year warranty!
See the photos of what your new display will look like below.
Feel free to ask questions-- info@fixyourboard.com
Apr 24, 2017 | Thermador Ovens
I have a Thermador Model SC301TP wall oven. When I try to Self Clean I get error F2 which I think is that it is a tempature issue. What should I do?
either the oven sensor is bad or see if the pins where it connects on the relay board have bad solder joints. re-solder first, then replace if needed.
Jan 18, 2015 | Thermador Ovens
Thermador Model SC301TP display panel stopped working
bad condenser on the display board. The display has to be replaced.
Nov 10, 2013 | Thermador SC302T Electric Double Oven
Control panel light is extremely dim
Should be C3 Capacitor on control panel board replace capacitor from Digi-key Corporation get panel out and see what C3 capacitor says what voltage and uf and temp celcius and order from them solder it takes two -10 minutes..
Apr 19, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Thermador single convection oven, SC301TP has inop LED panel. Dim, then blank. Solutions? I have Googled this complaint, and find many irate owners stating this is a common problem. Is there an LED panel...
Welcome to FixYa.
Regards,
Macmarkus :)
Dec 29, 2010 | Thermador SC302T Electric Double Oven
The LED control panel on my Thermador double oven is out
I solved this. Its a vaccum flourescent display. The voltages that drive it are reducing because the capacitors on the control board deteriorate with temperature. Replace the 3 capacitors and its good as new.mine still working after 2 years...$.20 at radio shack...or have a repair place do it for you...saves $250 for a new board
Nov 16, 2009 | Thermador SEC302 Electric Double Oven
Looking for the repair & users manuals for my thermadore wall oven sc301tp
Hello cfrisz,
I am new to the fixya and I saw that you were looking for a manual. I hope that this information can help you find one if you still are looking.
At this web they have a similar users manual or if you type in model (if there is another number on oven) number maybe they'll have it.
http://outdoorcooking.manualsonline.com/search.html?q=Thermador+SC301tp&submit.x=25&submit.y=28
or here is the main website (you might have tried it already)
http://www.thermador.com
in the contact us section there is a form to fill out and maybe you can get one that way. I'm not sure on response time. Most company's do not mind giving people replacement manuals.
hope this helps
Mar 07, 2009 | Thermador C302U Electric Double Oven
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Thermador SC301T oven
Thermador SC301T and SC302 stack ovens have a weakness in the radial capacitors on the circuit board behind the LED clock. They get cooked from heat. Here is the fix: Remove two screws from the control panel, located facing up at the bottom on the panel frame.. open the oven door to see them. The panel is then held in place by push in toggles at each end, pull towards you to remove. Carefully unplug the three wiring harness plug-ins, and check them to see if any wires are loose. Set the panel aside. Remove 3 screws holding in the LED assembly, and again unplug the wire harnesses, examining each for loose wires at the terminal. When unplugged, take the LED assembly to the bench, remove the plastic housing, and with a mini soldering iron and watchmaker's eyeglasses, or hobby magnifier,
identify, heat, and remove two 35v 450uf 105 degree radial capacitors, and one 35v 68uf 105 degree
capacitor. These are ordered from MCM Electronics (google it) and are p/ns 96K0326 and 96K0331.
Insert new parts, solder and clip excess leads. Carefully examine the printed circuit board around the area of the leads you just soldered, as some boards do not have the copper close enough to the hole to make contact. Scrape the green insulation from the conductor near the hole to expose copper and make sure your solder makes contact with the copper and the lead. Use your multi-tester when finished to check continuity from all leads you just soldered and their nearest neighboring contact on the circuit board. I found a loose wire on the harness to repair, and one contact on a capacitor did not have the copper close enough to make contact without extra effort. When all is completed, reassemble. Turn back on power at the circuit breaker. You may get an F7 error code. Off with the power again, wait 3 minutes. Restore power, go to oven and press the OFF position on the glass control panel... hold for 10 seconds, and the clock should now be steady at 12:00. Push clock position, reset clock for proper time. Test oven light on/off. Test bake/temp/convection buttons,
on/off. This is a good fix, and will save you about $469.00 in parts and $500.00 in labor. The new
105 degree centigrade high temperature radial capacitors replace old 85 degree, which fail, and your repair should last. Total parts and shipping costs.. about $10.00.
Nov 08, 2007 | Thermador SC302T Electric Double Oven
AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
May 21, 2007 | Amana AEW4530DDS Electric Single Oven
Thermador Professional Series PO301 Stainless Steel Single Oven Logo
119 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
