Question about Maytag Washing Machines
The washer is having a problem with large loads in the last six months it will try to aggitate or spin and stops someone told me to check the belt how do i get to the belt i have never worked on a front loader before neptune 5500bwq cloths washer
  • 4 Answers
Take back off the washer if belt is tight its probably the carbon brushes on the motor they set into either side of the motor with one spade connector on each one remove these and if worn replace them you can buy them from most appliance repair shops they should be under atenner
Posted on Mar 04, 2009
Tries to aggitate but wont everything else works
Sounds like the transmission is out. If it fills up and will pump out while spinning? Then more than likely that is it. Or could be the belt underneath. When it aggitates the belt go's in one direction then spin out it go's the other direction and turns the transmission and drum.
Dec 09, 2011 | Kenmore 24032\24036 Top Load Washer
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
Will not spin, lock light out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer aggitates poorly when it is loaded
Check belt tension. Motor capacitors weak. Check the spin mode. Finally check the motor.
Apr 03, 2010 | Washing Machines
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Won't spin or aggitate.
check to make sure door is locking when you close it before it spins or your spin belt is broken and it will not spin.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
GE Front Load Washer Model#GCVH6260F-Problem with no washing, spin or aggitate function but motor works fine...
try cleaning out the filter - it's behind the bottom panel (three screws to remove) you will see a round disk - unscrew it and pull out the filter. I have to clean ours every six months - it's too bad GE didn't put it in their manual, that this needs to be cleaned periodically.
Dec 11, 2007 | GE Energy Star WCVH6260F Front Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
