Question about HP Color LaserJet 4550n Printer
Printer prints blank pages.
I have a hp 4550n laserjet color printer. It continues to prints blank pages non stop with one print job. I tried troubleshooting it using the manual and at hp website. I also tried unplugging it but it has not help. I don't have the resourses to call in a technician. Please help.
  • kgcc96 Mar 05, 2009
    It work. How do I take the belt off?
  • 154 Answers
 it a transfer belt issue....there is a test you can perform to confirm. When the first page comes out of the printer blank, open and close the back cover. If the next page comes out with print on it, then the transfer belt is the issue. One thing you can try is take the old belt down to a service station with a good air compressor and then use the air compressor to blow the heck out of the belt until no more toner comes out.
Posted on Mar 04, 2009
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Apr 07, 2009 | HP LaserJet 4500 Printer
Hp 4550n printer not printing
How is the machine connected to the computer?
Mar 14, 2009 | HP Color LaserJet 4550n Printer
PRINTER CONTINUES TO PRINT BLANK PAGES NON STOP.
I found some info regarding this at the HP site. Go to this link and you will find the error code descriptions:
Good Luck!
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl08400#A10
Mar 13, 2009 | HP Color LaserJet 4550n Printer
Hp 4550n color laserjet printer prints blank pages nonstop.
Hi, I notice you have ruled out the transfer belt as asolution because it has 59% life left. Not to be rude but this does not exclude the transfer belt as the problem. I am 98%-100% sure that if you change the trasnsfer belt you will solve your problem.
I was doing work for a large corp. that sent a guy from Ohio to Colorado twice for this problem before he asked my opinion I told him tranfer belt. He was a Hero.
Hope this helps.
Mar 06, 2009 | HP Color LaserJet 4550n Printer
Color laserjet 4550n - printer will not print. It indicates that it is ready, however, it does not seem to accept print jobs that are sent to it.
try doing a self test print, if that works then you most likely have a communication problem between your computer and the printer. Try unplugging the usb cable and plug it back in see if you get any response.
Jan 30, 2009 | HP Color LaserJet 4550n Printer
HP laserJet 5000 Printer continually printing same page
laserjet 5000 printer A4 size printing right side line not printing .why?
Jan 14, 2009 | HP LaserJet 5000 Printer
HP 4500 Printer blank pages
Hi over the years on working on these printers I have found the transfer belt-kit causes this model to print blank pages i would try this
hope this helps
James
Dec 15, 2008 | HP Color LaserJet 3500 Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet 4550n Printer Logo
338 people viewed this question
Seeker5211
Seeker5211
