Question about Kenmore 22422 Top Load Washer
Washing machine will not spin or agitate, make a high pitched whining sound from the motor. i cannot move the basket by hand, is the motor shot?
  • Anonymous Mar 07, 2009
  • katytortora Mar 10, 2009
    washer will fill but makes a buzzing noise and will not agitate or spin in any cycle
  • Kenmore Master
  • 3,361 Answers
Replace the direct drive coupling on the motor.
Posted on Mar 04, 2009
The washer recently began producing a high pitch squeek during the washing cycle, and a louder than normal sound during the spin cycle.
The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wash basket does not spin
The bearing of the machine is damaged kindly replace the inner bearing as well as water seal your problem will be solved
May 08, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Motor whine w/ agitation & no high speed spin
try undoing the pump assy (just unclipp and move it aside) no need to disconect hoses yet. tyspinning now, if quiet then theres csomethin in the pump, you may get lucky and be able to pull whatever it is out!
Mar 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Motor whine during agitation & won't spin at high speed LSQ9200PQ
check to see if the tub has any side to side play to start then pull the motor and check the coupling the clicking is whats confusing
Mar 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Washing machine noise
my washing maching will not spin out all the water in the spin cycle.
Dec 20, 2006 | Hotpoint VLXR1020A Top Load Washer
Kenmore 22422 Top Load Washer Logo
85 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
