Question about Vacuums
I need a hose for a Kenmore vacuum. The serial number I found is D80501276 and model numder is 116. Another number on the bottom is 2841080. Where can I get these? Claire Salter
  • chris May 11, 2010
    this a canister or upright?
  • royzee May 11, 2010
    Hi Claie
    where are you?
    Rob
  • 20 Answers
Go to the Sears appliance center. They should have parts for vacuums at least up to 10 years old.
Sometimes vacuum cleaner repair shops have hoses that are used that may work. Check in your community.
Posted on Mar 27, 2009
I need a model number for the kenmore durapower vacuum. Don't have the manual can't find on vacuum
Hi There,
The model number will either be located on the bottom or the back of the machine on a sticker that also contains the serial number. All vacuums have to have this sticker, and serial number information on the machine somewhere. On uprights it's usually on the back of the machine towards the bottom, or on the very bottom of the floor nozzle part. On canister vacuums the model number will either be found on the bottom of the canister, or on the bottom of the power nozzle.
Hope this helped!
Chris
Apr 20, 2010 | Kenmore Vacuums
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
Kenmore model 116. 35912401 very very load
This could also be a problem with your direct drive. These machines have a gearbox instead of a belt. (a system they quickly went away from) You may want to first take off the bottom plate and make sure there is nothing in the brushroller compartment as a paperclip can make a machine sound like an aircraft engine if in the right spot.
My best advice would be take it to a vacuum store that does warranty service for panasonic vacuums (they're made by panasonic for sears) They should be able to tell you for free in most cases after listening to it for 30 seconds wether its the motor or the gear drive and how much the parts are.
Best of Luck!
Jun 08, 2009 | Kenmore 31913 Progressive Direct Drive...
After using the kemore vac it shuts off depending on how I m pulling on the tube part, it seems like there's a short where. Any help Thans,Steve the canister connects to the suction tube
This is a very common problem on your series of Kenmore canister vacuums. It is the result of a part inside the handle of the hose (where you would have your hand) which has broken and no longer properly supports and keeps in place the electrical receptacle that feeds electricity from the canister to the power head. If you provide a model number, I can provide an exploded parts diagram which will show you the likely culprit.
Dave
May 14, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Jan 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
4.3 amp Kenmore canister vacuum power switch has failed
You did not give the complete model number, but you can go to sears.com, click on parts and put in you model number. You will get links to click on, click on the cannister one and you get a picture breakdown and a parts list, you can also order after choosing the part you need.
Aug 09, 2008 | Kenmore 22812 Bagged Canister Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
128 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
