Question about Home
Kohler K1338 spa tub controls messing up
Back jets in the bottom position. If I turn up neck jet speed, that resets the back jets unless I press the down arrow on the neck jets first. Is this tub damaged?
  • 125 Answers
No it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
Posted on Mar 04, 2009
What is the best and safest way to remove the bacteria flakes from a Kohler Purist BubbleMassage Air jet tub?
http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1198327_2.pdf
Call 1-800-4KOHLER 1-800-456-4537)
some parts are under warranty,call them b4 you do anything,they will help figure it out,the link is your manual
May 31, 2015 | Kohler K-1110-G-96 Purist BubbleMassage...
Power trips out when jets are switched on
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
How to clean mold from jets on Kohler Spa tub
Mold on your jets can come from a variety of places but due mostly to the bacteria in the tub.
There are several kinds of cleaners to use in the meantime once you get your trim clean so you can prevent what you are experiencing.
Take the trim off and clean them in your sink. DO NOT put them in the dishwasher as it is too hot and will ruin your trim.
Here is a link to our site that has different options for cleaning the pipes and keeping the jets from getting yucky.
Maintenance Products
Rod
US Parts Center
888-521-6183
Jan 08, 2013 | Kohler Home
My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Idle adj screw vibrates out and the idle speed is high.
Hi Charles Gregory.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Make sure your spring that goes on the idle screw is in place.
You can also use some "locktite" thread locking compound on the threads of the needle if the spring is missing.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Oct 01, 2012 | Garden
We have a Kohler Purist Air Bubble Massage tub... the last couple days the dial has randomly started lighting up with the green light tracking down the middle and you can hear the motor or the jets on the...
This is sounding like a relay not working on the circuit board inside the control box. You will want to have a Kohler service center send someone out to have it checked. You most likely need a new control box.
Aug 14, 2011 | Kohler K-1110-AH-0 Purist whirlpool with...
"high pump" (jets) shutoff
look at circit board see if it s burnt replace
Sep 30, 2008 | Waterway 1 Hp 115 Volt 2 Speed Side...
Tub pump
This may be due to clogged jets. Also, if this is a new application....the valves under the spa may not be in the up position to release the water to run into the pump and through to the jets. It may be a top side control issue as well. Check for error codes.
Sep 16, 2008 | Waterway 4 Hp 230 Volt 1 Speed Side...
Home Logo
173 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
