Question about iRiver H10 MP3 Player
IRiver H10 20 gb System files
I have the problem where i need to get the updater and such.When i switch to UMS it doesnt work.The computer still doesnt register the iriver.It says its in emergency connection and then it just leaves it and goes into the normal USB connected screen.any help :D
    Problem Solver:
  • 18 Answers
Check around this forum for an answer: users
Posted on Apr 03, 2009
I replaced the battery in my iriver h10 20g. System file missing
was your player set to ums mode before running updater? to put it in ums mode you have to reset player by removing battery then reinstall battery then connect it to your computer turn on player and at the same time hold the button down with the o on it then run the updatera program again
Mar 23, 2009 | iRiver H10 MP3 Player
Every time I turn on my iriver h10 it freezes on the artists and won't go anywhere. How do I fix this ? resetting doesn't help
not sure what's wrong but try this..
hook up your h10 via the ums trick...
The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are always in UMS mode!
download and run the free playlist maker software called EASYh10. It will scan the music files on the h10 music folder and save a new playlist to your player.
Mar 03, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
4.6GB Iriver H10 Merory says 2.9GB remaining but there is nothing on the player.
Considered formatting disk?
For you what this would mean is just a complete refresh of the device (you will lose everything).
You will need to read everything carefully.
Check this out
http://www.misticriver.net/boards/showthread.php?t=14853
I converted my H10 to the "UMS" mode mentioned in the site a long time back (so I could directly transfer files as a USB mass storage device) and had the issue mentioned in that post. Works great. Converting to UMS mode is done here http://www.misticriver.net/wiki/index.php/H10_Firmware_Conversion:_MTP/UMS
You will also need the iRiver Plus software that you can download for free here http://www.iriver.com.au/iriver/index.cfm?pageID=10001&
Feb 17, 2008 | iRiver H10 MP3 Player
UMS
Try plugging it in to the computer first while the device is off. Then, hold the O key and press the power button. Worked for me.
Dec 25, 2007 | iRiver H10 MP3 Player
Getting music off Iriver
Bronte,
When you change your firmware from the "manager" version to e.g. the Firmware v1.85 UMS version, you will no longer need to use the iriver manager software to move mp3's around, you can just drop them on or from your iriver. The disadvantages are that:
1. by upgrading to the UMS version, you will wipe ALL your current music, so it will NOT help you right now, only after you have upgraded to the UMS version and placed mp3's on there again. The iriver will behave like an external thumb-drive, so you can use it on any PC without the iriver manager.
2. The UMS firmware will ONLY run in USB 1.0 speeds, so it will take up to 36 minutes to fill the iriver up with 1 GB of music (or in my case podcasts).
Regards,
Robert Ilbrink
Dec 10, 2007 | iRiver iFP-799 MP3 Player
Iriver H10 "System files missing".
Okay, my IRiver broke with the same kind of problems but I've managed to fix it!
First off i connected the IRiver to the pc, and whilst it was connecting, pressed the 'select' button (the one on the front with the circle on it) to force it to connect.
Next i right clicked on it and selected format to wipe everything off it (just to make sure it was blank).
Next, go to www.iriver.com and on the left hand side click Support->Download and click on H10 in the product box. On that page should be a file to download called "[MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only)". The download icon is just underneath the title of it, so download, unpack using winrar ot winzip etc, then double click and follow the instructions.
It wiped the songs off, but i have an IRiver that works! Its an awful product in my opinion, but better to have it working than not. Can't guarentee that it'll work for everyone but it fixed mine first time.
Hope it helps!
Sep 22, 2007 | iRiver H10 MP3 Player
Reacquire firmware from iRiver website
Nov 13, 2006 | iRiver H10 MP3 Player
Missing system files
how reinstall the firmware for E10? the laptop doesnt see the HD of E10.
Mar 16, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
46 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
