Question about Sony STR-DE305 Receiver
Sony Receiver STR-DE305
I was listening to music through a pair of cheap AIWA 40 Watt speakers model SX-NA302.  I was in the kitchen when I heard the music suddenly cut out.  I check the LED display on the receiver to discover it has entirely dissapeard.  I deduced that I must have wired the speakers incorrectly and blown a fuse.  The power supply seems to still work as the small orange light on for the bass boost in the lower left corner of the receiver regularly goes on and off when tested with the power button when it is plugged in.  However, if there is a sperate fuse to the LED display then i would assume the receiver would still play music and work regularly if the speakers are hooked up and I am pressing the right inputs.  This is not the case.  It will not work at all playing radio or audio output.  Unfortunatley I don't have the techincal/electtical knowledge of what the problem is or what may have occurred.  Does anyone know if this sounds like a fuse problem I could easily fix by finding and replacing them or could I have fried a critical component?  Any thoughts?  I'd be happy tp provide more details if anyone has any good input as to what the problem could be. Thanks,
  • evan_skwara Mar 05, 2009
    it does not work with other speakers...i tried.  So I opened it up and i cant find anything close to what resembles a fuse.  Im going to look through the manual and try and find some additional help.  There is a small green circuit board attached above the power box that mentions changing fuses but cannot be removed and doesnt look anything like a fuse.  Also the LED board is completey seperate components of circut boards...maybe i need to take that apart in look inside.?
    I replaced the fuse and as soon as i plugged it in and  turned on the power it blew the fuse instatntly....any idea why that could be?
  • 201 Answers
It's very likely it is a fuse - does it work with any other speakers or headphones? Is there any reset on the back of the receiver? If not, unplug it, remove the cover and check the fuse(s).
Rate if this helps :)
Posted on Mar 04, 2009
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Mar 07, 2011 | Pioneer SX-255R Receiver
PROTECT shows every time I turn my reciever on. It's a SONY model #STR-DE335
Turn it OFF. Look for shorted speaker wires or shorted speakers.
None found? Disconnect all speaker wires and try to turn it on.
Turns on ok? One of the speakers/cable pairs is shorted. Check them again.
No good? It's dead. take it to a tech.
http://www.retrevo.com/support/Sony-STR-DE335-Receivers-manual/id/387bh942/t/2/
Jan 08, 2011 | Sony STR-DE335 Receiver
I want to plug my Dell Computer into one of the Audio Jacks. Which ones do I use??
Any available Line Level input will work but NOT Phono. Get an adapter at Radio Shack to convert the probable 3.5 mm jack on the PC to an RCA pair.
In the PC: Get into the sound controls and max out the volume. Set the speaker type to large stereo or equivalent.
Dec 30, 2010 | Sony STR-DE305 Receiver
Where can I get the schematic diagram for my Sony STR-DE305
Ok go to this site and about 3/4 the way down you will find your model number... the model numbers are in order so just keep an eye on them as you scroll down...
http://www.schematicfanatic.com/samscit/sony.htm
just copy and paste into your browser
Sep 22, 2010 | Sony STR-DE305 Receiver
Sony STR-DH700 receiver
The one common component in this case is YOU. Maybe you might look at the impedances of your speakers to make sure you're not presenting too little to the amp. And turn it down. It's not like the result is totally UNexpected.
May 12, 2010 | Sony STR-DH700 A/V Receiver
Right channel low volume on Sony STR-685
Here you go buddy:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C225335&fes=true&mdl=STRDE685
Sep 20, 2009 | Sony STR-DE685 Receiver
How do I get video input from one source and audio from another?
I am confused and might be overlooking something obvious here. SO PLEASE do not think I am being disrespectful! IF you have everything connected properly, then your television is a separate device, independent of your Sony STR. You should be able to watch the picture with the Sony STR turned OFF. In turn, you should be able to LISTEN to the Sony STR with the television turned off. Although it isn't a lot of fun, it might be best to DISCONNECT all the cables (not your speaker wire) and go through the process of reconnecting everything.
Jul 09, 2007 | Sony STR-DE597 Receiver
611 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
