Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Where is the fuel filter located
Starts for a minute and shuts down. I shake it and refire and have same results. I lost the manual and dont want to start takeing everything a part.
  • 181 Answers
I have to ask ...what is the air pressure set at.very important that it is set correctly.if it isn't the unit will only run a few seconds then shut it self down.look at the back plate and see if there are any cracks at the adjuster boss or the plug boss.if there is one the pressure is not correct and the unit will not run right.but to set the pressure you need to have a gauge so the air pressure can be set to the right psi...
Posted on Mar 06, 2009
Have a 2005 f150 4.6 that stalls can it be the fuel pump is weak
Could be a fuel pressure regulator not working. Thus ecu complaining about fuel Pressure. probably not enough because the regulator is worn and leaking down so will not maintain the proper pressure. You will need to google the make model and fuel pressure regulator to find it's location or library and repair manual. Otherwise, you need to measure the pressure and find the spec for the required fuel pressure. Probably somewhere around 120PSI
Feb 28, 2015 | 2005 Ford F-150
Why does engine stop running and then start after a few minutes
check oil level, there is low oil sensor in case, when stopped all oil runs back down into case this alows it to start then it starts pumping the oil throughout and results in low oil shutting down engine (safety sensor) your probly down a liter or so
Oct 14, 2014 | John Deere 2009 Gator Traditional TX 4x2
Fuel pressure drop
replace fuel filter,pump could be weak.
Mar 02, 2013 | Cars & Trucks
I have a reddy heater model 170T ...Every time it starts and runs for 3 mins (app. ) Then shuts off . First the control panel, red lights , says it is a voltage problem ...now it says it is a fuel problem...
DESA bought out the assets of Reddyheater when they went bankrupt, I'd check with them for the manual. Torpedos are pretty bullet proof provided they are maintained.
A shut down at 3 minutes tells me its operating out of spec for one reason or another.
First thing is make sure your fuel is good... drain it all out, check for or crud in it, as such will raise havoc.If its clean, put it back in, if its contaminated, then get new fuel... don't run the old stuff down the drain.
Next, check the fuel filter and external air filter and if they are dirty replace them.
At this point, you need to put a gauge on the pressure port, your manual will have specs on this, and this is a mission critical adjustment. If its off, you will run too lean or too rich, and your machine will shut down in 3 minutes.If you can't get it set, it could be an air of fuel leak, or it could be a dirty inner air filter, or it could be fracture vanes at the pump. You can get a old style fuel pressure gauge from harbor freight for a few bucks to do this...
Oct 18, 2017 | Heating & Cooling
Have a compressor that is powered by a vanguard 16 hp v twin manual engine that runs perfectly but only for ten minutes at a time, any ideas
The vanguard engine has full pressure lubrication and a spin on filter..
if the oil is low, lost its weight, (Thin) it will shut off. Also depending on what carburetor this engine has (Walboro, nikki,makuni) it may also have a fuel shutoff solenoid located on the bottom of the carburetor.
This has a history of sticking, especially if the unit sat with fuel in it,
To test if its the oil pressure shutting down the engine, make sure you have the correct oil in engine (10w-30 or 30hd) look on the engine where the oil filter is located. There is a single wire (some have more) that leads to the pressure switch that is screwed into the oil filter housing. Unplug the wire and start the engine.
If it runs and does not shut off, its either the oil is too thin or a defective oil switch. If the engine shut off, then reconnect the wire.
The problem will be fuel carburetion or both.
To see if its the crburetor, remove the air cleaner and remove the air filter. Take a can of carburetor cleaner and restart the engine.. as the engine starts to die, spray carb spray into the engine. Did it continue to run? If so its fuel.. if not its carburetion..
getting to the carburetor will be a task. you have to remove the air shroud. If you need more info e mail me direct and I will give you links to briggs and stratton on how to tear the unit down to get to the carburetor and whats involved.. Or let a ocal shop look at it for you.
ke4tud@juno.com
Nov 07, 2009 | Air Tools & Compressors
1998 mustang 3.8 v6 will not start.
First I would check the fuel shut off switch, push down on the red button, switch is located in trunk. Make sure you are getting fuel and fuel pump fuse is ok. You can remove fuel line from fuel filter and turn key on to see if fuel comes out of hose and also get a glass jar and take a fuel sample to see if anything is in fuel. Sounds like you may be having a fuel problem.
Jul 09, 2009 | 1998 Ford Mustang
My engines shakes really bad once it starts. it idles for a few mins then it shuts down. this is after it shut down on me on the freeway. all power went of and it just shut down on me. i think is the
I'm no bona-fide mechanic, but I've done a lot of work on cars. It may be you have an engine seriously out of timing. Or you might have loose or worn engine or transmission mounts. If the engine was shaking badly before shutting down, one result of that may be in the fuel system. If your car has a carbeurator, the shaking may have wreaked havoc on your float. If you have fuel injection, I'm not sure what to think.
Hopefully, you've gotten your precise answer before I even read your problem!
May 11, 2009 | 1996 Ford Explorer
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
118 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
