Question about Canon PIXMA MX850 multifunction InkJet Printer
Trouble setting up fax machine on my canon all in one. It is attached to desk top with router and cable modem.
    Genius:
  • 2,120 Answers
Fax machines will not work reliably on digital phone lines.
Posted on Mar 05, 2009
I have a Cannon MX 850 all in one. My Fax is not sending upon receiving the fax signal from a long distant account. The number rings through, the signal begins, it rings once then stops. The local fax's...
REREINSTALL VIA A WIRELESS CONNECTION FIRST THEN ATTEMPT TO REFAX
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 25, 2011 | Canon PIXMA MX850 Multifunction Printer
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
My dell desk top keeps going on and off line with the airlink101
Try to access the setup page of your router and look for MTU settings. Set it to manual settings and set the size to 1492 then save. You must power cycle the router and the modem. Unplug the power on both for 30 seconds
Jun 12, 2009 | Computers & Internet
I have cable modem for my internet. I dont have any phone service
No. fax machines are ANALOG devices. Cable Modems, DSL, Vonage etc are DIGITAL.
Feb 11, 2009 | Canon FAX-L350 Plain Paper Laser
Attempting to connect netgear 624 to modem with desk top computer
first call comcast that you'll use a router with the modem.
then connect the cable modem to the router.
then connect the desktop to the router and use the supplied cd.
Dec 12, 2008 | Computers & Internet
I'm a little confused how to install this router I just bought. Model #wrt54g2. do I put the cd into my desk top which is already connected to the internet or do I install the cd in the new laptop I just...
Hi sheena -Is your desk top hooked up throgh the router? If not, plug your modem into the wan port on the router. The router should have come with a couple of short cables, most likely blue and yellow. Use the blue to connect your modem to your router. You can check the manual just to be sure. Use the ethernet cable that had been connecting your desk top to your modem, and plug into one of the wired ports on the router. I imagine you'll be using wireless for your laptop. Make sure that it is on. Put the cd in your desk top and run from there. Follow the directions. If you need more help just add a comment and I'll be glad to assist you further. If this solves your probleb PLEASE rate this as fixed. Remember. Need help? Just holler Sheena.
Jeff
May 04, 2008 | Computers & Internet
D-link router DI524 using next G external wireless modem
You can purchase a usb wireless dongle and attach to the PC. From then onwards you can set up a wireless network without connecting the usb cable for the router. The dongle will enable wireless capabilities on the pc. The only thing left is to have all devices running in the same workgroup.
Mar 09, 2008 | Computers & Internet
Wireless connection problem
Hello:
Ok...I am a bit confused. You must have a modem to connect to the internet...whether you are broadband (cable/DSL/wireless), Dial-up or T-1 or higher (TSU/DSU).
This is how it should run once you are sure you have the modem...
Modem....to router...pc to router. If you have no router...then plug ethernet cable from your modem to your NIC card on PC.
You will have to make sure your network card is working (check for flashing green light and one solid green. Then you can goto COntrol panel and run the wizard to connect to the internet...it should work.
What kind of router do you have? Also, what is the model number of your modem?
Let me know if I can help further.
Good luck my friend.
SeekPCRepair
Feb 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MX850 multifunction InkJet Printer Logo
57 people viewed this question
old marine
old marine
