Question about Hotpoint Ultima WF865 Front Load Washer
Wd865 spinning problems
Hi; i've just moved to a rented property. there is one of these machines but no manual. i put clothes on a fast wash at 40 degrees. when th ecycle finished the clothes were soaking wet. when i tried to spin; the machine was on but no spinning took place; i need help!!!!!!!!!
  • 4 Answers
PUMP IS BLOCKED OR PIPE LEADING TO IT ROMOVE FRONT BOTTOM PANEL AND YOU SHOULD SEE A ROUND THING WITH A SCREW IN IT REMOVE SCREW TWIST AND PULL OUT REMOVE DEBRIS AND TRY AGAIN IF THIS DONT WORK LAY MACHINE ON ITS BACK REMOVE PIPE FROM PUMP AND CHECK IT NOT BLOCKED WITH ANYTHING ITS QUITE AN EASY JOB TO DO
Posted on Mar 04, 2009
How come my washing machine cannot spin dry my clothes even I put the function for spin dry
not spinning fast enough
call an technician to check program board or for other faults
Sep 26, 2016 | Washing Machines
My whirlpool model LSQ9549PWO won't spin
have the motor checked out as it could have winding problems or start/run capacitor problems
Apr 05, 2017 | Washing Machines
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
Does not spin clothes very good. clothes are still very wet.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 29, 2011 | LG WM2050CW 40 cu. ft. Washer
Machne not spining fast enough to dry clothes, clothes still very wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 19, 2011 | Washing Machines
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
heatman101
Sep 16, 2010 | Kenmore Washing Machines
When the washing machine is in the final spin cycle, it shakes and beats against the inside of the housing. Problem started one night, every load since has had same problem. Hooked up washer with rear...
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of 3/4 plywood to make 1 1/2 inches put under the machine...thumbs up
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
My Hotpoint washer dryer WD865 moves around the room making loud noises when on a fast spin? The internal drum seems more loose than normal?
I had the same problem. You can open the top lid (2 screws at the back and then lift) The weight which is on top is secured by three bolts, all three of them were loose so weight was going from one side to another which made a terrible noise. Tightened the bolts and noise was gone!
Dryer still not working though.....
Aug 06, 2008 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Ultima WF865 Front Load Washer Logo
132 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
