Question about Brother IntelliFAX 4100 Laser Fax
Time date stamp on fax machine
If your fax machine is off and a fax is sent to you, would the time stamp reflect the time the fax was sent to you or the time it was received after you turned it on?
    Genius:
  • 2,120 Answers
The time it was sent, if they have the time set correctly on the sending fax machine
Posted on Mar 05, 2009
Does the Canon 3235i have a time stamp function for sending faxes?
Press> Additional functions > Communication Settings>TX fax settings
Feb 17, 2012 | Canon ImageRUNNER 3235i Black and White...
How do I change the date stamp on my fax machine?
just change the date under utilities, initial user data, date& time
Jul 13, 2010 | Konica Minolta Minolta FAX3900 Digital...
Need to program to date stamp incoming emails
Hi Deanna, unfortunately it is not possible on this unit to have the date and time stamped as that is produced by the senders machine, this feature is referred to as the station ID on your brother machine.
Mar 26, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Is there a way for me to leave a date/time stamp when sending a fax on my intellifax 1940CN?
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
Aug 10, 2009 | Brother IntelliFAX 5750e Laser Fax
How do I change the date stamp that prints when I send a fax
Ring the person you sent the fax to and ask them to white-out the date printed and fill in the required date.
Alternatively, you could read the Operating Instructions (http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL501%20Plain-Paper%20Laser%20Multifunction.pdf) and check page 17.
Jun 07, 2009 | Panasonic KX-FL501 Plain Paper Laser Fax
Wrong time printed on fax
  1. From the machine, press the [Menu] button until 'Machine Setup' appears on the top line of the display.
  2. Press the right arrow button until 'Date & Time' is displayed on the bottom line, then press [Enter].
    1. Enter the correct time and date using the numeric keypad. By default, the machine clock mode is set to 12-hour format; however, this can be changed to a 24-hour format (see the change the clock mode section below).
    2. Month = 01 ~ 12
      Day = 01 ~ 31
      Year = requires four digits
      Hour = 01 ~ 12 (12-hour mode)
      00 ~ 23 (24-hour mode)
      Minute = 00 ~ 59
    Note: To select 'AM' or 'PM' for a 12-hour format, press the * or # button or any number button.
    1. Once the correct date and time has been entered, press [Enter].
    2. Press the [Stop / Clear] button to return the machine to Standby mode
    Feb 19, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
    Verification stamp
    there is no function to print it on the fax you sent but you can have a come journal.
    press the following.
    function-7-4-start-1-2-start-2"should say always" start stop then this will give you what you want
    Jan 20, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
    Setting date/time stamp for faxes HPC6180
    Do you still have the manual that came with the machine? It should have the original setup instructions. I looked on HP's site and couldn't find anything that specifically answered your question, but if you don't have the manual any longer, you can download a copy from HP. It should have what you need:
    HP C6180 Manuals
    Sep 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Date and time stamp
    Here's the instructions for the date/time stamp.... I'll check on no. of pages and post that too.
    Press the 'User Tools' key.
    Use the right/left arrows until '2. Fax Features' is displayed.
    Press the 'OK' key.
    Press right/left until '4. Key Op. Tools' is displayed
    Press 'OK'
    Press '2222'
    Press 'OK'
    Press right/left until '7. User Parameters' is displayed
    Press 'OK'
    '1. Change' should be displayed - Press 'OK'
    Now 'Refer Op. Manual: Switch 00 :xxxx xxxx' should be displayed; use the right/left arrow until 'Switch 02 :xxxx xxxx' is displayed (xxxx being a bunch of 1's and 0's).
    When 'Switch 02' is displayed, the third digit from the RIGHT should be a 0. Press the '2' key, and that digit should change to a 1.
    Press the 'OK'' key.
    You should be back at the 'User Parameters' menu - just press the 'User Tools' key to return to the standby display.
    Presto, try it out!
    Please rate if this helps :)
    Mar 26, 2008 | Ricoh 3310LE Plain Paper Laser Fax
    Brother IntelliFAX 4100 Laser Fax Logo
    861 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
