Question about HP LaserJet 4250dtn Printer
Unwanted watermark I am working with a networked HP 4250dtn that prints the first line of text on each page diagnolly as a watermark. The settings in preferences are set to [NONE] for watermark. How do I get rid of this annoying anomaly?
    Genius:
  • 2,120 Answers
Turn it off in JetAdmin at the server.
Posted on Mar 05, 2009
2 Suggested Answers
redzventures
  • 149 Answers
SOURCE: Watermark problem
Sounds like a print driver problem. If the driver sits on a server and used by others do they have the same problem. If so, delete driver on server and reinstall. If the print driver is loaded individually on each pc - you will need your driver deleted and reinstalled (preferably from a different source). Hope this helps.
Posted on Jul 09, 2009
My documents have black lines running through them. whats the problem?
  1. Print a few more pages to see if the problem corrects itself.
  2. Clean the inside of the printer and run a cleaning page to clean the fuser.
  3. Replace the print cartridge.
  4. The printer might be due for maintenance. Check this by printing a copy of the supplies status page. If maintenance is due, order and install the printer maintenance kit.
    For an illustration of the 'lines' defect and information on other print-quality issues. please refer here.
Dec 14, 2010 | HP LaserJet 4250dtn Printer
Can't print on Network LaserJet Printer
If it worked before you updated the driver, go into the Device Manager and roll back the driver to the previous version. Sometimes new drivers haven't been fully tested, or they may contain bugs or may just be incompatible with an application that you happen to be running. If the old driver version works, stick with that.
May 28, 2010 | HP LaserJet 4250dtn Printer
How do i remove a watermark in 7.0 when undo will not work?
Here is the procedure for Acrobat 8.
To remove all watermarks from all pages, choose Document > Watermark > Remove, and click OK to confirm the removal.
Nov 09, 2009 | Adobe Acrobat 7.0 Professional
My hp 4250 dtn printer is carying(repeating) about an inch of text down the page three times as if the fuser is not working on that particular portion only
From the servivce manual:
Basically:
1 Inspect the drum for scratches or
other damage. Replace the print
cartridge for defects that repeat at
37.7 mm (1.5 inches), 62.8 mm
(2.5 inches), 54.0 mm (2.1 inches),
or 94.2 mm (3.7 inches).
2 Process a printer cleaning page.
See Running the cleaning page
manually.
3 If the problem persists, and the
defect repeats at 75.0 mm
(2.95 inches) or 94.0 mm (about
3.7 inches), replace the fuser (see
Fuser).
Jul 09, 2009 | HP LaserJet 4250dtn Printer
Watermark problem
Jul 08, 2009 | HP LaserJet 4250dtn Printer
All of my text is not printing.
Considering that the problem lessens further down the page, you most likely have a printhead that may be leaking (oozing) ink.
Once the surplus is wiped off on your paper, the ink flow is OK and the leak too slow to continue making the unwanted lines..
Try printing blank documents, you will probably see the lines with or without text printing.
I'm not certain how the printhead can be removed for inspection on that machine but it may need replacement.
Apr 28, 2008 | Lexmark X125 All-In-One InkJet Printer
Problems with Color printing
Click Start - All programs - HP - HP Solution center.
Click Settings - Print settings - Printer settings
Click on the Features tab. Set the print quality to best. Click on the Colors tab. Under color management - Enable the option Managed by Application. Click OK . close solution center. Try to print.
Dec 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
4250 printing problem
Make sure you have the paper tray guides pushed up far enough.
Print a configuration page by the printer panel and verify the tray settings are correct. If they differ, check the fences are pushed up and ensure the tray lever is set to STANDARD not to CUSTOM.
If the printed paper tray settings differ to what is actually set, you may have a faulty paper tray width sensor. If you still have trouble try the Restore Factory Settings Option. Remember to note any IP info if the unit is attached to a network.
Nov 09, 2007 | HP LaserJet 4250dtn Printer
Hp laserjet 4250dtn PROBLEM
try replacing the toner cartridge, if that doesnt work, let me know
Apr 03, 2007 | HP LaserJet 4250dtn Printer
HP LaserJet 4250dtn Printer Logo
308 people viewed this question
Seeker5211
Seeker5211
