Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Bottom Freezer has ice built up
I have a LG French door freezer with bottom freezer. Every couple of weeks I see the ice build up in the bottom freezer and I cannot shut the freezer door easily. So I take out the built up ice and then repeat the process every 2 weeks. The ice built up is on the base like a thick 1/2 inch sheet of ice.
What could be the problem.?
  • Anonymous Mar 16, 2014
    ice build up in bottom freezer
  • 400 Answers
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Posted on Mar 05, 2009
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
Jun 08, 2016 | Samsung RF4287HARS French Door...
Why does my freezer build up with ice in the bottom
is it a frost free model? if it is the defrost timer may be out or the defrost element may be bad. but if this is not a frost free model the door seals may be bad and need replaced
Aug 24, 2014 | Amana ABB1922FEB (185 cu ft) Bottom...
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
LG refrigerator Ice build up in the bottom freezer
Check the seal in the freezer, if it is leaking outside moisture can get in as well as cause things to defrost near the leak. Also make sure the contents aren't blocking the door to where the seal is leaking. If this is all OK then perhaps the fan units fan is not pulling the moisture out. It does tend to build up in most freezers a bit anyway. also
May 11, 2014 | LG LFD22860 Stainless Steel Bottom Freezer...
Ice is forming on bottom of refrig. under the freezer bin. Suspect it is the defroating system malfunctioning. Repairable without calling an expert?
Jul 05, 2011 | LG LRFC25750 Refrigerator French Door
My freezer is producing a lot of ice. There is buildup on the side racks, making it difficult to push/pull the top drawer. There is also frost/ice build up on the back of freezer and bottom floor. I...
This always happens when you don't have 'FROST-FREE' refrigerator. Unplug the power cord or switch off the freezer for about one hour or more when lots of frost stacks (maybe weekly). Turn down the cold lavel to 2-3 instead of higher if there are not so many items in the freezer.
Nov 12, 2010 | LG LFD22860 Bottom Freezer French Door...
Loud fan - ice build up in fan compartment.
Check resistance on bi metal thermostat/heating element.Make sure continuity is present on thermostat before defrosting.Advance derost timer if analog unit.
Sep 05, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
Ice tastes like plastic. New LG French Door.
Change the filter each week until problem is gone. LG is not usually hit with this problem. good luck.
Jun 09, 2009 | LG LFC25760 French Door Refrigerator
Water leaking from bottom of LG french door freezer on bottom
yep, total defrost is the 1st thing to do. if you want to speed the process, see the following page how to do is good luck
May 27, 2009 | LG LRFD25850 Stainless Steel French Door...
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
1,736 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
