Remove expansion slot cover so I can install video card.
What do you mean ? do you mean the back the computer.remove the electric cord shoot down PSU. no lights on the motherboard.lay the computer down left side up remove the side should be easy. now you see the videocard now replace it whit a new.be careful it can sit tight,and has a klaw in the front so be gently.
SOURCE: how to remove the hard
On Most computers, all that you have to do is remove the side (thumb screw on the back) use a screwdriver to take out the 2-4 screws on the hard drive, unplug the cables and pull out the hard drive. Be sure to discharge your static before rooting around in your computer by touching a large metal object for 10-20 sec. Good luck!!
SOURCE: I get no video output from the new PCI video card I've installed in my Think Centre
Maybe your old video card is on board because you don't mention it that you remove it. Maybe the problem is the cmos or the bios setup. If you can go to bios setup look for the onboard vga in disable it and look for pci vga option if disable enable it. or try to transfer the new pci video card to the other slot maybe the slot is damage or corroded that's why the contact to the board in not fucntioning.
SOURCE: How do I remove cover panel to install a wireless PCI card on an HP d530
Usually there are knurled screws on the back that secures the side panel or a quick disconnect lever that releases the side panel. After removing the side panel, you will need to remove the screw that holds the cover over one of the PCI slots if there is one. Install the wireless card and press down hard to make sure the card is inserted all the way. You will probably have to insert the accompanying CD if the computer doesnt automatically load the driver.
SOURCE: Blank monitor after installing new video card
One thing you can try is to go into the Bios and load the default Bios settings. Sometimes that helps in reassigning interrupts and I/O addresses with new hardware.
SOURCE: Upgrading Memory on Packard Bell MIT GHA20
If you look along the top edge of the escape/function/del keys, there are several small plastic tabs that hold the keypad in place. Use a very small flat head screwdriver to push these back from one corner across to the other, gently lifting the keypad as you go. When you press back the last tab, the keypad should just pop out but take care as it's connected by a cable at the bottom edge of the keys. The RAM slots are located under a thin metal cover under the keypad. You'll need a very small philips head screwdriver to undo this. After installing RAM, replace the metal cover then pop the keypad back in, bottom edge first and just press down the top edge and the plastic tabs should snap back into place. Hope this helps!
