Question about HP DeskJet 970cse InkJet Printer
Black ink cartridge
I removed my Black ink jet cartridge and had it refilled at Office max. The same cartridge was returned, filled, with a test strip. I reinstalled the newly refilled cartridge and got the message "remove and check black cartridge". I removed and reinstalled it about 6 times with no luck. What gives?
Thanks, John
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
Usually a contact issue. Try wiping the contacts in the carrier as well as the contacts on the cartridge. I have even cleaned the cart. contact with a pencil eraser then wiped them. If this does not work try a new cart.
hope this helps
Posted on Mar 11, 2009
I filled my hp 61 cartridges myself.I am having problems getting the ink to flow right,with the black cartridge
When filling cartridges yourself (i.e. DIY kits) you need to ensure that a proper vacuum prime occurs...often this is tricky if the internal foam is not properly 'wetted'. I suggest you take your HP61 ink cartridges to either Costco (most locations) or any Fry's Electronic Stores for ink refilling (typically ~40-70% cost savings vs. new cartridge cost)...the refill operators use a commercial grade ink refilling machine that preps, evacuates, cleans and then fills the cartridge automatically....followed by an electrical nozzle/jetting test. Anything goes wrong (at home) and you'll likely get a refund.
To find the nearest refill Costco store location and/or Costco pricing information, you can find this information at http://www.costcoinkjetrefill.com
For additional ink refill support information or advanced HP printer diagnosis/testing procedures for your printer model, please visit Inkjet411:
http://www.inkjet411.com
Aug 14, 2013 | HP DeskJet 1055 All-in-One Printer
I have a f4480 hp deskjet. How do you reset settings when you refill the ink (black) cartridge? Because even after injecting the ink, I still get the exclamation mark and orange light. And when even...
Some Hp printers, like Epson, require the cartridge to be reset. There is a chip on the cartridge that needs resetting.
This might work;
Place the HP 60 cartridge on a covered surface so that the metal contacts on the cartridge are facing you. Put tape over the top metal contact in the second column from the left-hand side, making sure the other contacts do not get covered. Put the HP 60 cartridge back into the HP printer. Print a test page when prompted. Take the cartridge out of the printer. Leave the tape on the contact that is already covered and also cover the top contact in the column at the far right, making sure no other contact gets covered in the process. Return the cartridge to the printer again. Print a test page. Remove the cartridge from the printer again, remove the tape from the metal contacts, and return the cartridge to the printer. Print the test page and the printer should read the cartridge as full.
Jun 18, 2017 | HP F4480 All-In-One Printer
Just refill our black ink for canon pixma ip 1200 and it gives out lines in beetwen image. How can i fix? it says it needs to unclogged but i kept cleaning through maintenance tab and result is still the...
Canon recommends genuine canon ink jet cartridges. If you bought a remanufactured ink jet cartridge and it did this, I would return it immediately.
But, since you filled it yourself, there's no recourse with the ink company, I don't believe.
Even if you were successful with refilling, they can only be refilled 2 or 3 times at best.
Jul 10, 2010 | Canon PIXMA iP2000 InkJet Printer
In the middle of a print job, my cartridge refill stops feeding ink. Printer MN J4680. Does this printer hold the cartridge # in memory in order to stop one from refilling?
HP printers do not remember the cartridge serial number to reject refills (certain Canon printers do though). It sounds like you have an air bubble in the sponge that is inhibiting ink from reaching the print head. I would guess that either you or the store/internet seller that refilled this cartridge hand filled it. These cartridges should be filled under a vacuum to remove air bubbles from the sponge and allow you to fully fill the cartridge (an air bubble takes up space that your ink could be occupying). I recommend Cartridge World or Office Depot for refills. Avoid internet sellers and refill shops that have one giant all-in-one machine that does the filling for them.
Oct 09, 2009 | HP J4680 Office Jet All-In-One Printer
Lexmark x5470
Let the ink settle in the cartridge for awhile. Make sure no ink is on the outside of the cartridge which adversely effects the signal to the printer.
Apr 14, 2009 | Dell Dimension 4500 + Lexmark Z35 Printer...
Printer error
I've encountered this same problem, it could be that the ink cartridges that you have installed in the printer are either running low or out of ink.
I had the problem also and found that after I swapped out my cartridges with new ones that I purchased the blinking yellow light on the Alarm and the black and color cartridge.
If you do not want to purchase new ink cartridges to correct the problem you can can open the lid to your multifunction and remove the ink cartridges and place them in separate plastic sandwich bags and take them to any office supply store; Office Depot, Office Max, Staples and tell an employee there that you have run out of the ink and that you would want to have the cartridges refilled.
I actually went to an Office Max in Houston with my cartridges and they told me it would be cheaper to have them refilled than to purchase a new set of cartridges; that after I looked online and compared what they charged for new cartridges actually saved me $40 to have the one's I already had refilled.
Nov 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Machine does not recognize refilled office max cartridge (black)
sir,
try to clean the cartridge on the copper side with tissue with and alcohol maybe the contact points doesnt meet or the cartidge itself is already defective. try also use an empty good cartridge just to to determine wich cartridge is defective.
yours,
alecz
Apr 23, 2008 | HP PSC 950 All-In-One InkJet Printer
I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
Good luck
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon all in one printer refill ink cartridges
i have just filled my mx 310 with the jet tec refills as instructed....but do not insert the rubber bungs...instead put some celotape over the filling holes... then with a needle...pierce the celotape where the hole is( pin *****).... this set up is now able to breathe as originally designrd. Mine prints fine now this has been done (trial and error), but i might try better quality ink next fill. Its also wise to use glossy paper 230gsm or over for good results.
GOOD LUCK.
Dec 20, 2007 | Office Equipment & Supplies
Test print great, document printing blurred
Have you tried a new cartridge yet? I know it doesn't make sense at first but I suspect the cartridge has a problem and your test print isn't exercising the printer like the Word doc is. If the new cartridge works than the problem is probably poor quality ink, the hole you used to refill isn't sealed correctly or the cartridge or jets were damaged in some way.
Sep 02, 2006 | HP DeskJet 3325 InkJet Printer
HP DeskJet 970cse InkJet Printer Logo
116 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
