Question about Epson Stylus C66 Photo InkJet Printer
Can't see how to open C66 printer
I'm trying to replace the waste ink pads and the construction drawings don't give a lot of detail on how to open the printer up to permit access.It does look like it will have to be almost completely dismantled.
Can anyone enlighten me?
  • 353 Answers
Yes, I'm afraid getting the covers off this family of printers is a nightmare - but possible. I have done a few but usually wished I hadn't bothered! Anyway - here's some notes on the job:
Normal 0 C6x and C8x Family Disassembly Notes Removing the end covers is the most difficult task. The service manual is very confused over this. Do not remove the thin “end plates” (dark plastic) - these are merely decoration. RHS and LHS are when looking at the front of the printer (opposite way round to the service manual). In the service manual, the red hooks hold the end covers, and the blue hooks the main centre cover..
End Cover RHS Release the hook at the top rear, and the two “prong hooks at the bottom, then prise the end cover off as far as possible. The end cover is now held on only by two hooks deep inside the cover (top front corner and top centre). It is impossible to reach these two hooks – brilliant design eh! These hooks are orientated downwards, and you need to lever up the flexible edge of the cover at the top, whilst trying to push it off. Do the corner one first, then the top one. The hooks are easily broken, so care is required.
End Cover LHS Release the hook at the top rear, and the one “prong hook at the bottom as before. There is a small square plate underneath with a >slot next to it. The purpose of this slot is not to release a hook inside, but to permit you to prise up the cover so that it can slide over this plate. There is also a similar slot near a foot – this appears to have no purpose. Then do the top hooks as before.
Posted on Mar 08, 2009
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
I recently replaced an ink cartridge on my Epson stylus C66 and now the ink light and paper light are flashing on and off in turn and I can't get the printer to work. Do you know if there's an easy way to...
yes, this means that the ink waste counter is already in its peak and you need to reset it. try to download the inkpad reset utility through your computer. you will know all of the details from there on once you read them.
it would be
Sep 23, 2009 | Epson Stylus C66 Inkjet Printer
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
Aug 10, 2009 | Epson Stylus C66 Inkjet Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Printer sending message
Waste ink tank/pads getting full.
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need to actually get a SERVICE MANUAL, to refer to that removal procedure.
You may want to try doing a general search on the "" printer repair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.
Jun 22, 2009 | Epson Office Equipment & Supplies
How do you dismantle the C66 Case to get to the waste ink pads ?
It's to difficult to describe here, find diagram at
Jun 08, 2009 | Epson Stylus C66 Photo InkJet Printer
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
Oct 24, 2008 | Office Equipment & Supplies
Epson stylus c66
The Waste Ink Pads are saturated and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
The C64/66 service manual can be downloaded from here:
Should you decide to have a go at changing the waste ink pads, let me know and I can supply some notes on opening the case - it's a pig and the service manual is not that helpful.
Oct 22, 2008 | Epson Stylus C66 Inkjet Printer
Epsom stylus C66 inkjet printer
This problem is probably caused by a blockage in the ink waste pads. Over time, particularly with increased nozzle cleans the pads get saturated. These can be replaced by an Epson Engineer at a cost of about £30-£40 but probably more effective to buy a new printer. This usually happens when the printer is between 2-5 years old.
Hope this helps
Oct 10, 2008 | Epson Stylus C66 Inkjet Printer
Epson stylus c66
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
Mar 27, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 Photo InkJet Printer Logo
128 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
