Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Kenmore Upright freezer needs cleaning under bottom shelf
I hsve a small upright Kenmore with wire rack shelves. I like to know how to remove the bottom shelf from the four hole- 2 on each side of inside of freezer.
  • Anonymous Mar 26, 2014
    model 23724 bottom freezer shelf falls out. The shelf has two holes on each side but the shelf arms are too short to stay in all the holes.
    Bottom shelf support has two holes on each side but shelf is too short to stay in holes.
    President:
  • 267 Answers
Most of the sears freezers . lift up on the shelf that will unlock it then slide it left or right ( it may move a little hard ) that will unlock the other side , lift and remove ( one side at a time ) ... you will see its not that hard , its just hard to put it in words .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 04, 2009
Cactus bob has it right. you really have to shove it to the left or right though. one side will not feel as loose and that is probably the locking side. the other side will be the loose side. if you lock side is on the left as mine was, you much push the entire shelf to the left very hard. does that make any sense? at first it seems like it wont work, but give it a good shove and it's made to eventually go left.
Posted on Aug 21, 2009
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
How to remove the bottom shelf to clean inside bottom of freezer?
There will probably be small rubber devices on the shelf close to the wall pull those off and pull shelf up till center of hole then pull shelf that way and tilt out
Apr 28, 2014 | Frigidaire 14 cu. ft. / 396 liter Upright...
How to remove bottom shelf to clean inside bottom of freezer?
Good Morning Wayne,
I see that you want to remove the bottom shelf of your Frigidaire freezer, to clean inside the bottom of your appliance. To remove the shelf, you will pull it out and lift it up. If you are having troubles getting the bottom shelf out, I suggest contacting a local authorized technician for further assistance. They will be able to diagnose exactly what is causing the shelf to stay inside your freezer. Hope this is helpful.
-Best Regards-
WP
Danby upright freezer 1166w top and bottom shelves frosted in none on middle shelf could i have a problem
Probably there's a freon leak (refrigerant) that has to be fixed (remember this is a seal system and shouldn't leak)and then recharged.
Oct 05, 2009 | Danby 4.7 cu. ft. / 133 liter Upright...
Frost build up on 1 shelf then 2 shelf and so on - hard freeze on top soft freeze on bottom upright 7.5 freezer
door gasket sealing properly kids hanging with door open? condenser clean? if its a forced air condenser if it is a static freon problem. Tom
Jun 16, 2009 | Kenmore 7.5 cu. ft. Upright Freezer 28702
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Rack on freezer is not working
low on freon. buy new . as freon level drops , ability to feed all shelves falls off. the last shelf to freeze is usually the first one to not freeze ,as charge goes away. time for new, cost to fix to great.
Nov 22, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Upright 13 cu.ft freezer- uneven freezing
no it sound like there is a problem with the seal system where the freon is kept this model does not have a fan because is the shelves get frosted so there is a leak or restriction so try calling a tech but i would just buy a new if i was you since to fix will cost about the same
Nov 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Upright freezer.Two shelves freeze up. One doesn't. Why and is this a problem
look to see if the shelves are in fact not shelves but evaporator coils . if the shelf is connected to small tubing, then that tubing flows freon that freezes the shelf. if its clearly not connect to any tubing or piping then its just a shelf and gets residual cold from evaporator shelves. if it is connected to tubing like the others and not getting cold then you have whats called a restriction. . particles have plugged the tubing and no freon is feeding the shelf. if that is happening then consider having a pro recover the gas , unplug the tubing , replace the drier and recharge it. if its an older unit and you are getting by then maybe not worth the expense.
Nov 01, 2008 | Kenmore Freezers
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
414 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
