Question about Xerox WorkCentre XD105F Laser Printer
After re-filling the cartridge, some the ink getting inside the copier. I took both the cartridge and the drum part out and cleaned them off with a cloth of the excessive ink. I wiped the round drum part with the cloth now there is no image on paper after I try to make a copy. I don't know if I could have damaged the drum section of this copier or if the cartridge is not working properly. If the drum section is damaged, would this be a sign of that kind of damage. I don't want to buy both a new drum part and a cartridge.
  • Xerox Master
  • 5,568 Answers
The drum should never be touched with anything; the surface is sensitive in the extreme and I suspect you have finished it off.
The refilling of the toner cartridge isn't really a DIY job on this unit.
Yes, it will cost a few dollars but it's either this or a new unit. Although now retired, I had very good service from Precision Roller and I can recommend them highly:
Xerox toner & drum cartridges
Posted on Mar 04, 2009
A 1/4 inch stripe of magenta ink runs down the side of all pages printed.
Hi ,
Dirty print out is mostly due to cartridge related issues. In this case it seems that magenta is the issue. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located just behind the green drum inside the cartridge. Try cleaning it or replacing the Magenta Cartridge. If required, get the PCR Roller changed by a professional.
Let me know if any further clarification is required.
Hope it helps! Good Luck!
CreativeTECH
Mar 03, 2011 | Brother MFC9450CDN Colour Laser MFC...
Printer says color inkis empty I can fill the weight is heavyer then the one I took out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Run the cleaning process on the printer first. Then test it again, the cleaning process should not care what the state of the ink is reading. If the problem is still there…Turn over the ink cartridges so that the gold strip is facing up and set them on a stable surface. Then, dip cotton swab in distilled water and clean off the top and sides of the ink cartridges, but be careful not to get the gold strip wet. Dry off cartridges with a paper towel and then with a cloth clean the back of the carriage and then replace the cartridges in the printer.
Warning: Do not leave the ink cartridges outside of the cartridge carriage for more than a half hour, as the ink will begin to dry.
Aug 24, 2009 | Office Equipment & Supplies
Photocopier prints black lines on one side of the page.
what copier is it? please specify brand and model? line is usually either created by main charger or cleaning blade
Mar 18, 2009 | Xerox Office Equipment & Supplies
Poor and inconsistent quality from the black ink.
the problem seems to be un-even distribution of ink. try a different and new ink cartridge. Since you are refilling the cartridge, the ink inside of the cartridge is getting magnetized, there by, the ink stick to the drum of the cartridge and don't distribute the ink evenly. shake would clear it. you need to demagnetized the drum.
Feb 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printing 1 1/2" down right side of paper
You have a defective toner cartridge, drum should be clean when you looked at it, the blade is failing. Is the cartridge remanufactured (or compatible)? Although they usually work well (depending on the supplier) there are sometimes defects
Nov 25, 2008 | Canon PC-980 Color Copier
I BOUGHT A REPLACEMENT CARTRIDGE FROM A COMPANY THAT REMANUFACTURES THEM THRU XEROX,ANYWAY THE INK TONER CARTRIDGE IS FOR YOUR Z-85II COPIER AND THE INK WAS EVERYWHERE WHEN I TOOK IT OUT OF THE PACKAGE AND...
You are right about the cartridges having a seal. These toner remanufacturing companies are known as TONER PIRATES, they don't change the drum or cleaning blade, they just dump in toner.
Try wiping the inside with STRETCH AND DUST cloths before you put the new cartridge in.
If that doesn't work, I have to recommend that you get it cleaned, as the spilled toner will blow straight through a regular vacuum.
Oct 28, 2008 | Sharp Office Equipment & Supplies
Jet ink on printed invoices
Clean inside for toner spills
check fuser may be worn
check drum ( green Cylinder of toner cartridge) --Rotate--
Jul 15, 2008 | HP LaserJet 2430 Printer
DRUM ERROR
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
It happens because Brother decide that we are morons and cannot figure out when a drum is dead and so they make the printer refuse to work after a certain amount of time. This resets their dummy counter.
Jul 07, 2008 | Brother MFC-7820N Printer
Copies come out with splotches
replace the drum. take out toners and clean inside real good. check your exit rollers to see if they have any ink on them. be sure you use genuine hp products.
Jun 26, 2008 | HP LaserJet 2840 All-In-One Printer
Xerox WorkCentre XD105F Laser Printer Logo
52 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
