Question about Microwave Ovens
2 month old microwave is arcing in the centre under the plate?
This has happened to 2 previous different brands?? first arcing, or some sort of bright light, and smoke, then on my old microwaves, the plastic in the middle under the plate actually caught fire. The first model which was 2nd hand and in perfect condition, was in use for a year when there was a sudden loud pop and a massive puff of dark smoke came out from underneath the microwave!!
I am wondering if this an electric circuit/wiring problem in my home. If it makes a difference the microwaves have always been positioned on a thick sturdy kind of shelf, but above a very vigorous washing machine when on full spin??
Another fact to mention that maybe of some relevance is that i have an electric pay as u go type system, that has shut off at times, and when the electricity is turned back on the microwave has still been plugged into the mains, although the arc/smoke problems haven't occurred straight after??
  • Microwave Ovens Master
  • 9,098 Answers
You just need to remove the stirrer cover from time to time to clean off any accumulated grease from it and the parts behind it.
And be sure to clean up any spills quickly.
Your owner's manual should cover that.
If for some reason you do not have your owner's manual, please reply back with your brand and model number so we can help you find it.
Posted on Mar 06, 2009
My Daewoo Micro Wave Was Spitting Flames Last Night Due To A Hole In The Wave Plate
Hello Stephanie.
Get a new filter and try again.
Otherwise scrap the micro.
It the filter plate rusted through, or is it burnt?
The microwave's Magnetron-wave-guide is just behind this filter plate.
Looks like a small tube with a silvery cap with hole in center.
Very hazardous condition here.
The high energy from it is damped by the filter.
Is there food in the micro when arcing happens?
An empty micro will arc.
Sep 23, 2017 | Daewoo Microwave Ovens
What causes a ge spacemaker above the range microwave to quit heating and makes a deeper pitched noise?
This louder, 60 cycle hum is usually caused by a bad magnetron. The unit will not heat when this happens. Repair cost can exceed $100.
Dec 29, 2017 | GE Spacemaker JVM1540 Microwave Oven
2 months old. bought brand new. and just stopped
These things will happen. You are aware that these appliances have a 12 month warranty so return it to where you purchased it from.
Feb 17, 2010 | Microwave Ovens
My built in AEG electrolux microwave has started arcing (only 3 years old) and the flexible plate covering the stirrer appears to hve a tear in it - what can I do? I live in Northumberland, UK.
The plate should be an insulator and NOT causing the arcing.
Arcing is caused by EITHER not having enough food load with moisture content, OR using containers that have METAL in them INCLUDING bowls with metallic decorations or silvery/gold painting.
Sep 09, 2009 | AEG Microwave Ovens
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
3 new or fairly new microwaves same problem????
Did you properly orient the exhaust vent and take out any shipping materials under the exhaust vent? Sounds like the exhaust fan itself may be overheating, smoking up the innards of the microwave and then the smoke is escaping though the hole where the carousel is located.
Either that or someone built the shaft of the carousel rotator out of the wrong material and the microwave is actually trying to cook (or arc) that piece, causing a fire.
Neat stuff!
Mar 05, 2009 | Microwave Ovens
Microwave Arcing inside
Found the online service manual and did the troubleshooting necessary to determine it was the magnatron. I have one ordered.
Nov 03, 2008 | Sharp Microwave Ovens
Bright flash inside microwave
try a different brand of popcorn & let me no what happens
May 12, 2008 | GE JES1290 Convection/Microwave Oven
3 microwave ovens in 18 months - all won't heat up - what is causing the recurring problem?
Carla, Sorry to read of your troubles. Your unit that is only 2monts old should be under warranty, or did you receive any warranty?
What you describe as " the noise one gets when metal is put in by mistake". The noise is Arcing of Microwave Energy. Do not operate a Microwave Oven DRY (without something inside that will absorb the Microwave Energy. A Dry-Run Microwave Oven will feed-back upon itself and do damage.
If your unit is matched to the electric needs, both voltage and cycles, then I would not get another one of the same Model.
Feb 02, 2008 | Microwave Ovens
Microwave Ovens Logo
156 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
