Question about Sony VAIO VGN-B3VP Notebook
Hi my laptop has died no power it could be the motherboard
  • TruckNoob May 11, 2010
    Ok, try this. Take the battery out and plug the AC adapter into an outlet that you know works.
    Check the green light on the AC adapter. If green light is on,
    Check the AC cable between the wart and the Laptop.
    Check to see if is snug.
    Check to see if there are any frays. Next
    Check to see if the power plug on the Laptop is loose or lint inside the the plug.
    Use a tooth pick to try and move the plug inside the Laptop (remember, battery should be removed) If its solid, Then
    Think back, did you smell a burnt circuit? Did you let your Laptop sit on a fluffy surface like your bed? If you did this, your burnt out your CPU.
    Did you loan it to some one? Spilled a drink on it?
    Let me know it that helped.
Won't power on with AC. Bat Died. Why?
This is more than likely caused by the DC jack in the laptop breaking free from the motherboard or bad solder connections under the plug. the only solution is to dismantle the laptop down to the motherboard level to address the issue.
Apr 16, 2012 | Gateway Computers & Internet
Hi, I really need some help. I want to know whats wrong before taking my hp pavllion dv600 to service centre. Problem is that the charger doesn?t charge the battery at all. Charger is fine with other...
If the power supply does not run the laptop without the battery, then the problem is the jack in the laptop, over time the plug breaks free of the motherboard causing intermittent operation or no power. If the power supply runs the laptop without the battery, it is the charging circuits on the motherboard that is the issue.
Jan 04, 2011 | Computers & Internet
Power problem
first dint buy (not original) adapters and replace the original adapter try to charg battery
Jun 22, 2010 | HP Compaq Motherboard
My toshiba laptop will not show "charging" when it is connected to the wall and computer. I am unbale to turn it on becasue of battery dying. i have tried different outlets etc... no luck. has anyone heard...
The cause of this is likely either that your power supply-cable is broken, or that the power input-socket on the laptop motherboard is. Usually this occurs if one trips over the cable. You should firstly use a volt meter to check if the first is the case. If not, it's the latter problem which is a harder nut to crack. If you're lucky that it's not the motherboard itself, but only the soldering, and you are skilled with a soldering-iron, you might try to open the laptop and fix it yourself. If it's the motherboard, I'm afraid that you're out of luck, and some money to buy a new laptop.
Apr 12, 2010 | Toshiba Satellite A135-S4527 Notebook
Laptop shuts down and all lights incl ac adapter light goes out
You can go into the BIOS and look for the temperature to see if in fact the system is overheating.
Jun 15, 2009 | Intel Motherboard
HP Pavillion 6000 battery issues
Hi Steve, If you haven't gotten any batteries to work properly at all and the problems are different each time, I would say the motherboard is shorting out the batteries and causing weird problems. One last thing to try if possible..
Try a known good working battery, if that battery doesn't work then its verified that the motherboard is bad. If the known good working battery works in that laptop then you got a bad batch and it will be a battery problem.
Since your laptop turns on with the ac adaptor means that the ac adaptor is good.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Dead sharp pc-ax40
You can try reseating the memory and the hard drive if you can get to it, but it sure sounds as though the motherboard is shot.
You can take it to your local computer repair shop.
Good Luck.
Mar 15, 2009 | Sharp Computers & Internet
Can't power up Acer TravelMate6292-301G16Mn.
Motherboard. Find a local repair shop or someone on craigslist who will diagnose it for free. Wait while they do it. It should only take 5 minutes for them to confirm that it's a motherboard problem.
Feb 22, 2009 | Computers & Internet
When I turn on the power to my laptop, tries to turn on but dies
According to me, you should check your power adapter. I think it is not working and is not producing sufficient power supply for your laptop. And due to this, your laptop have not been charging.
Jan 17, 2009 | Intel Motherboard
The power light is on, but the monitor is off
its the motherboard. If you laptop powers on for a few seconds then dies, it is the motherboard/systemboard.
Oct 30, 2007 | HP Compaq Business nx7010 Notebook
Sony VAIO VGN-B3VP Notebook Logo
105 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
