Question about Universal MX-900 Remote Control
Switched from comcast cable to verizon fios
My mx 900 remote no longer controls the digital set top. it only turns the tv and receiver on/off. i am not able to use the guide or menu at all with my remote. its RF. Please help!
  • Anonymous May 02, 2009
    I have the same problem. I downloaded the Genesis software. Did you find a solution, or website with it's programming codes?
SOURCE: genesis mx-900
I have the same remote and need to reprogram the remote too.
Genesis X900 has anyone had any luck finding out how to reprogram this remote yet?
Posted on May 16, 2008
  • 23 Answers
SOURCE: MX-900 Universal Remote Control
you might want to reprogram it with different codes. it's a classic problem.
Posted on Oct 15, 2008
  • 95 Answers
SOURCE: I can not get my MX-900 Universal Remote to connect to my compute
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Posted on Aug 12, 2009
toolkits
  • 1099 Answers
SOURCE: Controller will only turn equipment on and off.
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
Posted on May 20, 2010
SOURCE: we have an MX 900 universal remote and got a new
You will have to go to universalremote.com and use the Contact Us (top right of webpage). Fill out the form and tell them that you need the editor software. They will have you fax them a form with your remote serial number and some other information and then they will provide you will a link to download the editor software.
Posted on Dec 17, 2010
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
1988 KAWASHO TV: Need remote control codes for VERIZON FIOS Remote Control
You may want to try a different universal remote, like the Logitech Harmony.
Apr 07, 2008 | Onkyo TX-SR605 Receiver
Switching from comcast to verizon fios my rx-v663
This usually means your receiver is not passing the HDCP copyright protection correctly. Try using component cables instead, if your receiver supports it.
Nov 25, 2009 | Yamaha RX-V663 Receiver
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
Can I set up tv remote to also control cable box?
Just bought a Vizio 22" 1080 p TV and need to set up a Verizon Fios remote for it. The codes for Vizio for the remote do not work. Can anyone help me with this.
Steve
Jan 14, 2009 | Panasonic TC-32LX85 LCD TV
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Genesis mx-900
May 04, 2008 | Universal Remote Control DIRECTV Universal...
Code for Verizon FIOS remote Control
Code 1292 worked like a charm for me!
Vizio SV421XVT
Dec 11, 2007 | Televison & Video
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Oct 24, 2007 | Onkyo TX-SR605 Receiver
Universal MX-900 Remote Control Logo
147 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
