Question about Dell Dimension 4600 PC Desktop
After sitting idle for 24 days my Dell 4600 PC doesn't power up
I tried many things including a new cord and checking all connections..it just will not turn on
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    When diagnosing a power issue, work from the source back to the machine. You tried a different cord, did you try a different wall socket? (Are you using a power strip?) Try using the cord that is attached to the machine to power the monitor. If this works then you know that the cord and socket are good. To continue working backward, the next component is not the motherboard, it is the power supply unit. (That the cord plugs into...) When you try to turn on your system, do ANY of the fans on your machine turn on? (There is a fan located in the PSU, and there are usually at least two fans in the machine...one on the CPU, and one case fan.) One time I began to take everything apart on my own machine, only to realize that my power supply had a "hard switch" on the back of it that was in the "off" position. -- (The mark was shaped like a circle and the other side was a dash, the dash means "on")
    Anyway, if no fans come on when trying to start the system, the problem may be the power supply. To test the power supply is not too difficult, you will need a thin paperclip bent into a "U" shape. First, make sure that the power cord is NOT connected to the back. Second, disconnect the PSU from the motherboard and all the drives that it is connected to. Third, after letting the PSU sit unplugged for a little while, insert one end of the "U" shaped paperclip into the terminal with the green wire. The other end should go into the black wired terminal next to the green one that you just used. Finally, plug the power cord into the socket and the wall...the fan on the power supply should start spinning if the PSU is good. You could take it one step further and use a multimeter to test the ends of the wired for appropriate voltage.
    ****Note: Never take the case off of the power supply unless you are a qualified technician...inside the PSU there are very large capacitors that can hurt you. Working with the ends of the wires however is safe.
    This seems like a long confusing response, so if you have a question, please ask.
    SWS
    Sergeant:
    Champion:
  • 357 Answers
Take your machine to your local computer repair shop for daignostics.
Good Luck.
Posted on Mar 21, 2009
My Dell Dimension 4600 computer will not turn on when I hit the On button, Instead it show a small greenish light near the On button under a Power symbol. I have checked all the cables and cords and...
Open up the side panel of the PC case, remove the BIOS battery for about a minute. Then reinstall it in the correct orientation. This will clear the BIOS to default.
You would have the best possible chance of success.
Try use another Power Supply, and try using onboard graphics and Graphics card to test if it is the problem.
If it works after resetting the BIOS the enter the BIOS by hitting del key, check the manual, at statup, and enter the correct date and time.
The day it stoped working, was it fairly warm? PC could have overheated and fried the Northbridge, thats the chip under the heatsink below your CPU cooler!!!
In that case you would have to purchase a new Mainboard!
Please tell me if this sovles your problem.
Please take the time as I have to rate this solution.
Thanks.
Oct 31, 2010 | Dell Dimension 4600 PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
When I start the Dell Dimension 4600, it says "Enter password." But when I type the password, the cursor won't move, and no asterisks appear for each character of the password. After repeated attempts, the...
First thing I would do is to reset your CMOS by:
1) Power down.
2) Remove power cord.
3) Push power button in and hold for 15 seconds.
4) Open the case.
5) ground you self to the case for a second. (touch bare metal)
6) Remove the battery for 30 seconds.
7) Replace battery.
8) Double check all your connections and cards if any.
9) Close the case.
10) Connect power and power up.
Your diagnostic lights indicate "Other Failure". (The one on the right is amber, correct?) That could be anything. Here is a reference for your diagnostic lights:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886
Try resetting the CMOS first and comment back.
BTW, this will remove your password too, so you will have to go into the BIOS and reset. You will probably get a "Configuration change" message when you first boot up. Press F1 to go in and then do a Save & Exit.
Thanks for using Fixya.
Dec 12, 2009 | Dell Dimension 4600 PC Desktop
How to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Regards,
Pp
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
Not connecting to Internet
The Nic on the main board sounds like it went bad. You can purchase a pci nic card at best buy or so install that and it should be good to go.
Jan 15, 2009 | Dell Dimension 4600 PC Desktop
Dell dimension 4600
check in the bios that it is your new hardrive it is seeing, and not your old one still sitting in thr bios memory, as taking out the battery doesnt always delete the cmos memory.
There shoul be an option in the bios to auto recognise the drive
Aug 24, 2008 | Dell Dimension 4600 PC Desktop
No anything
Flashing amber power button indicates a failure of the power supply.
Jun 14, 2008 | Dell Dimension 4600 PC Desktop
No boot
Things to Check When No boot...
1. Have you connected all the power cable?
2. Do you see any display?(including the power lights glowing)
3. Does the screen show you any blue screen error message?
4. Do you hear any beep noises?
5. Have you tried to install any third party hardware or software?
6. What do you think could have caused the issue?
Mar 28, 2008 | Dell Dimension 4600 PC Desktop
Help me
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Dell Dimension 4600 PC Desktop Logo
91 people viewed this question
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
