Question about Emerson Black Microwave Oven
How do i change the bulb on my emerson mw8991sb microwave
  • Emerson Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Emerson 900 Watt Microwave MW8991SB glass
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
ginko
  • 19396 Answers
SOURCE: Emerson mw8991sb is not heating up
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
  • 8909 Answers
SOURCE: my turn table doesn't turn on my microwave
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
But here is a basic methos if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Posted on Jan 04, 2011
  • 34 Answers
SOURCE: The ceramic fuse has expired in my microwave
On my own microwave I have noticed there is a panel on the interior wall with removable screws...I'd suggest UNPLUGGING it first (of course!) then checking out the interior of that.
Posted on May 18, 2011
How do I change light bulb in microwave MW8991SB
remove the entire outer cabinet is only way
Feb 10, 2015 | In Microwave Ovens
Replacement glass turntable
Go to www.ebay.com Type make and model of microwave oven, refine search to plate.
Jul 11, 2012 | Emerson MW8991SB Microwave Oven
The ceramic fuse has expired in my microwave (Emerson MW8991SB). Will you tell me where the fuse is located?
May 18, 2011 | Emerson Microwave Ovens
On the Emerson MW 8992 SB microwave oven how does one change power settings,e.g., from 100% to 50%?
Emerson MW8991SB 0.9Cu.Ft. 900 Watt Touch-Control Microwave Oven, Stainless Steel has the same face as your microwave. I own one of them Look at the bottom three uo to the left it says (POWER) push the Power button it starts at 10 and goes to 1. 10 being the highest and 5 being half power and 1 being the least. then select the amount of time you will cook by punching in the numbers.
Jan 17, 2011 | Emerson Microwave Ovens
Microwave is not heating food it turns two red lights on when trying to heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 07, 2010 | Emerson MW8991SB Microwave Oven
Need a manual for MW8991SB
Hi
Thanks for using FixYa. You can view/download the manual for your Emerson MW8991SB Microwave from this link--
Emerson MW8991SB Microwave Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 06, 2009 | Emerson Microwave Ovens
Emerson 900 Watt Microwave MW8991SB glass turntable broke in two Replacement parts anyone?
Mar 02, 2009 | Emerson MW8168B Microwave Oven
Mircowave oven
CHECK THE PROBLEM ON THE BURN THERMAL FUSE ON YOUR UNIT.
Aug 16, 2008 | Emerson MW8107WA Microwave Oven
Need plate inside
try partstore.com
or
microwaveglasstrays.com
Feb 22, 2008 | Emerson Black Microwave Oven
Emerson Black Microwave Oven Logo
207 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
