I HAVE A JVC MODEL HD 52Z575 THE PICTURE IS NOT VERY BRIGHT AND THE COLOR IS OFF ON 2/3 OF THE SCREEN DO YOU THINK IT IS A LAMP OR OTHER PROBLEMS I REPAIRED TVS FOR YEARS BUT QUIT BEFORE MODERN TECHNOLOGY CAME OUT
  • 2 more comments
  • jdavis6217 Mar 04, 2009
    will that make it dim
    it looks like a regular crt that needs degausing
  • jdavis6217 Mar 10, 2009
    LAMP DID NOT REPAIR
    STILL LOOKS THE SAME
  • 10,515 Answers
The most common concern with rear projection TV's that have pictures that are not clear is that the lenses and mirror needs to be cleaned. Most manufactures allow access to this area, lenses&mirror, from the front of the TV by removing the screen ***'y. That is the easiest way but not always the most obvious.
If the the brand is Phillips/Magnavox the problem will more than likely be contamination of the CRT's fluid,Ethylene Glycol, in which will have to replaced.
If not clear meaning the colors are seperated then the TV will be experienceing a convergence problem.
Good Luck.
Posted on Mar 10, 2009
  • 583 Answers
The lcd controller is faulty.its a small panel board which takes care of screen lights and schedules it.u can buiy this part from the link below: http://www.partstore.com/Model/Matsushita/JVC/HD52Z575.aspx
thanks. do rate the solution accordingly.
Posted on Mar 04, 2009
  • 1,000 Answers
You might remove the light engine and make certain the lens are clean and not cracked or broken.
I have read several articles referring to this problem. I would defiantly investigate before purchasing a new bulb or engine.
Let me know.
regards,
  • 10,594 Answers
Please replace Lamp in TV and problem will resolve.
  • 19,396 Answers
It can be one of the mirrors in the light tunnel that is out of place.
  • 3 more comments
  • Ginko
    Ginko Mar 04, 2009
    If you have like a shadow that cover part of the screen and colors are dim it can be one of the mirrors that cover the internal surface of light tunnel that had fallen out of place.
    If instead you have a net line with no color, that can be a fault regarding the three-chip D-ILA (Digital Image Light Amplifier) system that is used on this model.
  • Ginko
    Ginko Mar 04, 2009
    This TV does not have CRTs, it has an high-pressure mercury lamp.
  • Ginko
    Ginko Mar 04, 2009
  • Ginko
    Ginko Mar 04, 2009
    That D-ILA is an LCD panel that regulates intensity of light and colors, and that is faulty, otherqise is the light tunnel, but light tunnel gives you a kind of shadow. I think it is the D-ILA system gone.
  • Ginko
    Ginko Mar 04, 2009
    The faulty parts can be the D-ila screen that cost about $300, the D-Ila cables, that can cause failing from part of the screen, or the chips on Ila control circuit located on digital board.
    You can buy all parts here HD52Z575
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
JVc hd ila both led blinkin fast. Blck screen. There was no mesage . how to trouble shoot
your lamp is burned out, buy a new one online and replace according to the instuctions sent with new lamp. this a cheap and easy fix-dont believe anyone that tells you different-they are usually people that work in the tv repair industry and want everyone to think they belong at NASA!!!
Dec 04, 2009 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52Z575 TV that has briteness an color purity problems.
From what little I have read about these TVs parts are High Call JVC 1-800-233-1060 Ask for TECH surrport them them what your problem is If it doe turn out to be Light engine Call UED for price of rebuilt one 1-800-648-6657 Also go to website ENCOMPASS look up your Model number they will have a listing of Parts 1-800-638-3328 You can try Downloading to USB stick in formation to it reprogram eeprom to TV sometime this will correct problem! GOOD LUCK with the repair.JVC downloads.
Oct 01, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Loss of yellow tint
Yea light engine and it's expensive.$950.00 though is high for the part.Shop around.
Aug 31, 2009 | JVC HD-52Z575 52" Rear Projection...
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC HD-ILA PROJECTION T.V. #HD-52Z575
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
Nov 29, 2007 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
