Cartridge problem w/ Lexmark 2500
Hi I have a problem with my Lexmark 2500. I changed the cartridges with the with the same old ones that I had refilled. I did this before, but strangely this time, once I put the cartridges on the lights for the cartridges still blink and the printer does not do anything. Any suggestions? Thanks Samuela
    Problem Solver:
  • 6 Answers
Ok so I am the only one that I have seen on the net with the solution. If you use the 28a and 29a cartridges not the 28 or 29.....This will only work with 28a or 29a. What you have to do if you want to refill these is "pop" the top off the ink cartridge......If you do this it will read a full cartridge everytime. If it will not notice your cartridge you have to get a new one as the circuit on it is shot.......
Posted on Sep 29, 2009
What numbers for cartridges for lexmark 2500
hello
go to the link below , it will give you the user guide : in it you will be able to get the part numbers for the various cartridges.
http://www.lexmark.com/publications/pdfs/2007/2500/v3709407_en.pdf
Item Part number Average cartridge standard page yield is up to1
Black cartridge p/n 28A
High yield black cartridge p/n 34
Color cartridge p/n 29A
High yield color cartridge p/n 35
Photo cartridge p/n 31
please rate my service
Nov 30, 2010 | Office Equipment & Supplies
Tip
Lexmark 2500 series ink cartridge problems
ok, i called lexmark and finally figured out the problem so many people are having with the unsupported cartridge error. it seems there are a few different varieties of 2500 series printers. mine for example is a 2500, came with a 2500 series user manual, but is actually considered a 2580! this is huge for the ink cartridge- as a 2580 is the only version that takes number 2 and number 3 cartridges. i switched from the 28 and 29 cartridges that the manual said to use and the box said was compatible for and put the 2 and 3 cartridges in, and it worked fine. i complained to lexmark that the manual is deciving and costing people money. she offered to send me the right cartridges free of charge. i hope this helps some of you!<br />
on Jan 04, 2011 | Lexmark X2500 All-In-One Printer
How do i reset my lexmark 2500 series for a cartridge that has been refilled.
one cartridge is black any you put into the printer and one is a cartridge is color an then you take old out and put the new two cartridge in.one at a time.
May 20, 2010 | Lexmark X2500 All-In-One Printer
Replacement cartridges
  • Black cartridge 28A or 28
  • High yield black cartridge 34
  • Color cartridge 29A or 29
  • High yield color cartridge 35
See user manual link below - Page 40The support site is here http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Direct link to the manual http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Lexmark X2550 All-In-One Printer
How do I change the ink cartridge on lexmark x3480
Please use lexmark solution center... here it is:
To install a cartridge using the Solution Center:
  1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
  2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
  3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
  4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
  5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
  6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
  7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
  8. Make sure the cartridge cover is closed and that there is paper in the printer.
  9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
  10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
  11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
  12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
  13. You can now exit from the Solution Center.
Thank you......
Jan 15, 2009 | Lexmark X3480 All-In-One Printer
Printer wont print :(
hi 59dragonfly,
did you just change your cartridge? is/are these genuine cartridges?
try to remove the cartridges. power off your printer, wait for 10mins then power it back on and also put back in the cartridges.
get back to me :)
Jul 01, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexark X7350
If the contacts are different, then you may have bought a damaged cartridge, or just simply the wrong cartridge and this would explain why your printer cannot recognise the cartridge. Make sure you bought the same number Lexmark cartridge as the old one. Return it to the store as a damaged cartridge if it is the exact same cartridge. Lexmark would not change the design of a working cartridge to exclude customers from using a printer.
Sep 07, 2007 | Lexmark X7350 All-In-One InkJet Printer
172 people viewed this question
k24674
jasbo
jasbo
