Question about Car Audio & Video
CD error 2001 Mustang GT
Is it better to pull the fuse or disconnect the battery to get my CD player functioning properly?
  • 398 Answers
Battery, if it works.
Posted on Mar 05, 2009
06mustang gt 1000shaker system does not want to recieve disc
Its a common problem with the Ford CD mechanism. Unfortunately, it's likely broken. If it is a five disc, try disconnecting the power to the head unit by pulling the associated fuse for about 15 minutes. This may reboot the cd mechanism. Its a long shot but has worked for some.
Apr 04, 2014 | 2006 Ford Mustang
98 mustang cd player doesnt work
I installed car audio equipment for over 38 year befor i (Retired) End all so am a (Certified) Electronic (Technician) It will cost you more to have it (Repaired) Then to just go out end buy a decent new one.
Oct 26, 2012 | Audio Players & Recorders
2001 yukon denali cd player will not play or eject and reads error
You can try one of two things. You can pull the fuse to the radio and leave it out for about 15 minutes to allow the radio to reset. Hopefully this is the case. If you don't know where your fuses are, you can also do what's called a dead battery reset. You disconnect the negative side of your vehicles battery and leave off for at least 15 minutes. This will reset all the computers too. If this doesn't work, just remember that the radio is 10 years old and if wasn't taken care of properly will malfunction at some point. Good Luck
Aug 17, 2011 | Car Audio & Video
I HAVE A 2002 MUSTANG GT. THE CD PLAYER IS MESSING UP AND HAS BEEN FOR A WHILE NOW. IT KEEPS TELLING ME CD ERROR AS SOON AS IT IS STARTED. IF I PUSH THE LOAD BUTTON IT TELLS ME ALL THE SLOTS ARE FULL, BUT...
Sound like the cd player itself has the issue. It will have a small sensor in the player to tell the user if all the slots are full with cd's or not. thats either gummed up or blocked from doing its proper job. as far as the cd error goes, thats your laser. If its still the stock 6 disc cd changer, its a good time for you to concider changing out that cd deck.
good luck bro
May 20, 2011 | 2002 Ford Mustang
Where are the radio fuses for my 2006 for mustang gt...even since the car was new the shaker 500 has had issues...the cds get jammed and the cd player says error and wont eject the cd
There could be two fuses that service the radio; one identified as 'Accessories' in the main fuse box and possibly a second in-line fuse inserted in the 12V line and under the dashboard.
Jul 03, 2010 | 2006 Ford Mustang
My 2001 mustang gt convertibles interior lights stay on all the time, even with the switch in the off position and doors closed other than pulling the fuse or light bulbs what should i look for first to...
only tow thing can cause the problem , roof lamp or any doors switch or lock, check first replace light, then disconnect all door lock wire one by one and try light is going off or not, if not then problem with electric control module.
Jan 26, 2010 | 2001 Ford Mustang
I have a sony audio cd stuck in the cd player. Ejection error displays when ejection button pressed. How did I get it outwithout damaging player?
Try disconnecting the battery for 1 min and after reconnecting the battery, try ejecting the CD from the radio. This should work, and if it does not then it's mechanical problem with the CD player. Good luck and hope this works.
Nov 12, 2009 | 2002 Mercury Mountaineer
2002 ford mustang-cd player says cd error and won't work- cd stuck in it?
MY 2002 GT HAD THIS PROBLEM! ALL YOU HAVE TO DO IS DISCONNECT THE POSSITIVE SIDE OF THE BATTERY FOR A FEW MINUTES AND REATTACH IT. WHEN YOU GET BACK IN THE CAR THE CD WHILLE BE HANG OUT OF THE CD PLAYER! I DON,T KNOW WHAT CAUSES THE PROBLEM, BUT MINE SEEMS TO DO THIS WHEN IT IS HOT OUTSIDE (95 OR HIGHER) WELL I HOPE THIS HELPS SOMEONE!
Oct 20, 2008 | Car Audio & Video
2001 MUSTANG CD PLAYER QUESTION
there should be a little pin push button on cd changer (kinda hard to see) that you put a pin into front it releases the cd dock you should be able to get disks out that way the other way
after this is done take your car sterio to a service sterio technition and have your deck cleaned and serviced so that you can enjoy it for a long time
May 08, 2008 | Car Audio & Video
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
