Question about Dishwashers
Thick white coating inside dishwasher and on dishes
Maytag Timer Control built in dishwasher. I've increased water temperature setting and run hot water in sink before running. The coating is thick and all over the inside of the washer and on all dishes.
  • 640 Answers
That's lime build up.Buy some c.l.r. (calcium,lime,rust) remover from a supermarket.Pour a cup in and run a long cycle,you may have to repeat this until it's gone.
Posted on Mar 05, 2009
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Dishwasher not drying dished with any heat source. Dishes washed in cold water.
Most dishwashers are plumbed to the hot side of the hot water side of the faucet. This should provide hot water for washing the dishes. Perhaps this dishwasher was plumbed to the cold water side by mistake.
Most dishwashers have a heating coil most of the way around under the bottom sliding/rolling dish rack. The heating coil may not be working, which would be consistent with the dishes not drying at the end of the cycle. Possible causes include incorrect setting selected on control console (push buttons) or timer, heating coil disconnected from electrical source at one end or both ends, faulty control circuit inside the timer, faulty wiring between the timer/control circuit and the heating coil, burned or pitted contacts in the control circuit.
May 23, 2011 | Dishwashers
Have a Maytag MDB4000AWW dishwasher that now leaves white residue on glassware. I think that the water is not getting hot enough. Does this model increase the water temperature, if yes how do you test that...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 08, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
My dishwasher is not cleaning my dishes the inside of my dishwasher is thick with white residue
hello. I can help you. Make sure your dishwasher is empty. Then pour two cups of vinegar into the dishwasher. Next run the hot water into your kitchen sink until it is as hot as it gets and start your machine. Run it on the longest and hottest cycle you have..
This will clean your machine. Repeat the process with more vinegar if you need to.
Once your machine is clean, be sure to always run your sink water until it is hot before turning on the dishwasher and also rinse your dishes. good luck with it.
Sep 13, 2009 | Maytag 24 in. MDB5600A Jetclean II...
I have residue on dishes with a maytag mdb7600
clean out the food trap in the bottom inside of the dishwasher.  Also your water may not be hot enough...either select hot wash or increase your hot water heater temp.
Mar 24, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing f the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Won't Stop
Water pre-heating
Water pre-heating
Aug 03, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher leaves film, smelly water
You need to use something with citric acid too try and clean out the calcium deposits inside dishwasher, you can get cleaner at the store or run a can of frozen orange juice thru it or a small bottle of apple cider vinegar. Do this with no dishes inside.
Jul 14, 2008 | Whirlpool 24 in. DU900PCD Built-in...
Dish washer
Water pre-heating
Water pre-heating
May 14, 2008 | EuroTech EWF150 Front Load Washer
Very long cycle as before
Water pre-heating
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
May 10, 2008 | Kenmore 24 in. 16532 - Multiple Color...
Dishwashers Logo
650 people viewed this question
Top Dishwashers Experts
