Question about Sylvania Televison & Video
Vcr tape is stuck and won't eject, so TV shuts off
I did remove the faulty VCR tape manually but now I cannot download a perfectly good VCR tape in the slot ... there seems to be an obstruction like the old tape was still loaded. There is a spinner revolving when I first turn the TV on.. Can you help or do I need to take it in for a repair??
Posted on Mar 05, 2009
    New Friend:
Junk it costs too much to fix
Posted on Nov 26, 2012
I had the same problem so I had to
Open the unit and inspect the cause
A half-round gear was broken so I put
It back together with epoxy and now
Works great! It is labor intensive, but
With a little patience you will do it.
If things get nasty, just throw it away !
Posted on May 07, 2011
3 Suggested Answers
premtech
  • 934 Answers
SOURCE: Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Posted on Jun 04, 2007
frcs68
  • 1605 Answers
SOURCE: CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
Posted on Apr 16, 2009
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
My Philips tv that has vhs player as part of the tv is stuck on T eject. It won't stay on and it will not accept tape or change from T eject. I do not have remote control or manual. This tv was sold in...
The mechanism on VCR are complicated. You can open it (make sure its not plugged in). Try to rotate the motor manually that is responsible for the loading mechanism. So that you can eject the tape. Or if you want you can just take out the whole VCR mechanism so that your TV will not shut off. if you are succesfull in ejecting the tape manually and also pay close attention to the mechanism. Do not put another tape in there unles you find out what is causing the mechanical prblem.
Jul 02, 2010 | Televison & Video
Funai tv/vcr combo has a tape stuck
It shuts off due to an error or mechanical problem, this is a safety feature. Sounds like the gears are worn/stripped and needs to be serviced/replaced. The tape can be remove by opening the unit and manually ejecting it if its important to you.
Aug 06, 2009 | Funai F3819D Combo
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
Vcr trouble
this combo unit as far as i know has only one power source which is in the vcr unit. if the vcr has a problem it affects the tv likewise. i beleive u did removed the tape, but unfortunately you misaligned the mechanism of the vcr which will in turn sense an error causing the automatic shuts off of the vcr and likewise the tv. u need to bring it to a qualified service technician if u dont know anything about this.
Jan 05, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Televison & Video Logo
354 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
