Question about Jenn-Air JMC7000 Microwave Oven
JenAir JMC7000ADB Transformer
I hope some one can help I have a Jenair JMC7000ADB the Transformer that they made for this unit has been discontinued this transformer fit the may tag and Whirlpool unit the transformer number are the same for all Jenair Maytag and WHirlpool which is 56001221 Im trying to find a replacement for it there has to be another transformer that can fit this unit mine is makde by Eledex but they wont respond to my request of a replacement for it. The number on the transformer is DW-N95AO-16th if any one can shed some light on what transformer I can use in its place would be very helpful thank you in advance my email address is JHughis@aol.com
  • Anonymous Mar 10, 2009
    yes but I was hoping to find an after market one for less money is there any cross ref to this transformer from another company or something
  • Jenn-Air Master
  • 9,086 Answers
Sears Parts Direct has them in stock here.
Posted on Mar 06, 2009
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
How to get to fuse in my jmc7000adb
On this model, the fuse is located in an inline fuse holder is the wiring harness.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 24, 2012 | Jenn-Air JMC7000 Microwave Oven
When the microwave is plugged in but not running there is a buzzing/humming noise.The unit works fine and the buzzing/humming continues when in operation as well.
That noise you hear is loose laminations in the standby/controll transformer. It is no more than a nuisance.
The transformer can be replaced by contacting the manufacturer and browsing for a dealer near you.
Hope that helps.
Dec 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave not working jen air
The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
Sorry
Apr 24, 2010 | Jenn-Air JMC7000 Microwave Oven
LOOKING FOR A UNIVERSAL MICROWAVE TRANSFORMER 230V 1400W
It is hard to find a universal with such a high output , I was able to get the part number for the transformer that goes into the unit you listed.
WB27X10893
should find it online ok , here's where I found it
http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=JVM1640SJ&Page=1&SortBy=price&SortDirection=desc#PartsearchSKUList
Hope this helps.
Phil
Apr 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turntable makes a noise
Just dont listen to Mr Miller. He rambles way off subject and will say anything to feel like he is special.
All it takes is very fist sentence where he suggests it could be magnetron bad. Geee, if that were the case your microwave wouldnt heat/cook so you wouldnt be here having a noise problem would you? Its kinda like the mechanic saying your noisy brakes could be caused by a empty gas tank.
Cause? - could be motor that operates turntable going bad, food or something lodged anywhere in moving parts of turntable operation which includes unseen area, or moving part that is been somehow bent or moved (unlikely without impact to microwave or previous work done possibly leaving something loose).
Solution? - I am ignorant of specific assembly of your microwave but on many you can access motor from bottom (unplug microwave first) and replace motor yourself if you are somewhat mechanical. The cheapest easiest 1st step would be clean very well around all parts and even clean any debris you find when taken apart, then recover and turn on to see. Not the likliest but its cheap and easy and you have to take apart bottom to replace motor anyway so not really much extra work.
Mar 30, 2009 | Kenmore 62702 Microwave Oven
My microwave is a 2005
jl, first, are you sure that you have power? Plug something else in to check. Also, unplug the unit, wait a full minute and repower. Sometimes this resets the units. Second, fuses are generally located inside the keypanel area. With the unit unplugged, remove the screws holding the panel on. Inside, you will find at least one fuse. You will also find thermo sensors. They are black, about the diameter of a dime and 3/8 inch thick with two wires coming out of them. Check them for continuity.
Dec 18, 2007 | Frigidaire PLMV169DC Microwave Oven
Whirlpool MH6151XHT-1 - No Power - Stumped
First change all the fuse and check whether it works or not, if it does not work than as per your finding the secondary transformer could be the issue, the secondary transformer tap down the voltage fro 230-240/110 to required control board voltage. the best thing if the unit is opened then the right problem can be found but as per your description either fuses are faulty or the secondary transformer.
Dec 12, 2007 | Whirlpool MH1150XMQ Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
404 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
