Question about Shimano Xtr Mountain Bike Dual Control Brake/Shift Levers
Needing advice on finding xtr repair parts
I have an xtr rapid fire shifter and brake. The screw broke to the mounting bracket to the handle bars. It stays on but needs the screw to tighten it up. Just needing the info on where to find the part or an idea of an after market part that fits.
  • 484 Answers
You can use a good old metal screw for this. If the back of the screw hole is open, just get a coarse threaded metal screw that is approximately the fight diameter and use it. Or, if you want to be precise (and far more safe), take the screw you do have to a hardware store, or a fastener supplier, and have them set you up with the correct screw. i do not know where you live, but if you Google map "hardware store" you should be able to find one pretty close by.
Posted on Sep 07, 2009
Samsung French door fridge freezer handle came loose. The ***** on the right side fell into the back of the handle attachment so it won't go flush with the fridge.
Hello Marilyn;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the inside liner of your fresh food section.
Usually the door handles are held on in one of two ways.
1.) Inspect the sides of the door handles. Are there small allen wrench screws - tighten them.
2.) Ok, no screws on the side. There are mounting brackets screwed onto the door. At times the screws become loose. Use a little muscle and pull the handle up hard to release from the bracket. Tighten the screws on the bracket to the door. Position the handle back on the bracket and pull the handle down hard until secure.
Mar 03, 2016 | Samsung Refrigerators
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
I recently bought a samsung side by side refridgerator i accidentally scratch my handles, and are deep scratches as i can see the white material beneath the metallic coding.
Hello Dimakatso;
My Name is Peter. I am a retired field service refrigeration technician.
I assume you wish to remove the handles to replace them.
These handles are usually attached to the doors in one of two ways:
1.) There are two 3/32" Hex key screws, one at the top and one at bottom of each handle. Unscrew ( Back off) the screw until the Handle comes off. It is not necessary to completely remove the screw.
2.) There two brackets mounted on each refrigerator door. One at the top & one at the top and one bottom of each handle. There are two screws on the handle, one at the top and one at the bottom. These screw fit into a oversize hole on the bracket. There is a slot below the oversize hole that you push the screws on the back of the handle down into. So, to remove the handle pull up on the handle. You will need some muscle to pull the handle up.
Over time handles with the mounting bracket on the door become loose. You have to remove the handle (pull up) and tighten the bracket mounting screws on the door. Put the handle back on and push down to lock.
Oct 27, 2014 | Refrigerators
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
The housing of my brakes on the handle bars is loose and keeps moving. how do i tighten it so that it stops moving when i apply pressure on it and/or squeeze the brake lever??
If the screw is all the way tight and still slipping ... try to find a fatter part of the handle bar to mount the grip to. You will probably will not find any such that is convenient for you to continue to use the brake ... remove the grip, wrap some electrical tape around the handle bar, reattach the grip. Tighten it and give it a try.
I hope this works for you
a
Oct 12, 2009 | GMC Denali Road Bike
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Remove ignition tumbler
lock cylinder removal
Section 11-04: Steering Column 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Lock Cylinder Removal
  1. stf~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE ELECTRICAL CIRCUIT NECESSARY FOR DRIVER SIDE AIR BAG MODULE DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BATTERY GROUND CABLE MUST BE DISCONNECTED PRIOR TO SERVICING OR REPLACING ANY DRIVER SIDE AIR BAG MODULE SYSTEM COMPONENTS.
    Remove the steering wheel (3600). Refer to the procedure in this section.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal procedure.
  1. Disconnect the ignition switch electrical connector.
  1. Remove the ignition/shifter interlock cable mounting bracket bolt and position the ignition/shifter interlock cable mounting bracket and the ignition/shifter interlock cable (3F719) aside.
  1. Remove the four steering column upper mounting bracket bolts and lower the steering column (3C529).
  1. Use a hammer and chisel to make a groove in the head of each of the two ignition switch lock cylinder bracket bolts.
  1. Remove the two ignition switch lock cylinder bracket bolts with a screwdriver and discard the bolts.
  1. Remove the ignition switch lock cylinder and the ignition switch lock cylinder bracket.
Installation
  1. Position the ignition switch lock cylinder and bracket and install two new bolts, tightening them only enough to hold the ignition switch lock cylinder in position.
  1. With the key in the ignition, verify the operation of the ignition switch lock cylinder. If necessary, reposition the ignition switch lock cylinder until it operates properly.
  1. Tighten the ignition switch lock cylinder bracket bolts until the bolt heads break off.
  1. Position the steering column and install the four steering column upper mounting bracket bolts. Tighten the steering column upper mounting bracket bolts to 9-14 Nm (80-124 lb-in).
  1. On vehicles equipped with tilt column, remove the upper mounting bracket retaining pin.
  1. Position the ignition/shifter interlock cable mounting bracket and install the bolt. Tighten the ignition/shifter interlock cable mounting bracket bolt to 4-6 Nm (35-53 lb-in).
  1. Connect the ignition switch electrical connector.
  1. Install the multi-function switch. Refer to Section 11-05 for the installation procedure.
  1. Install the steering wheel. Refer to the procedure in this section.
  1. Inspect the shift interlock system. Refer to Section 07-05 for the procedure.
Apr 07, 2009 | 1995 Mercury Tracer
Shifter sloppy, having trouble getting it into gear.
There is a bracket with two torx screws that gets loose. You need to tighten that. You will need to remove the plastic and metal shield under the dash, above the brake pedal to see the bracket. Look up above the brake pedal and wiggle the the shift lever and you will see what needs tightened. Worked for me.
Oct 01, 2008 | 1996 Mercury Grand Marquis
Shimano Xtr Mountain Bike Dual Control Brake/Shift Levers  Logo
313 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
