Question about Vizio L32 32 in. LCD HDTV
Vizio with terrible color
I jsut bought a Vizio VOJ32, or maybe it's V0J32, which has terrible color with either my direct TV or DVD's. I have gone through all the settings and to get only close to decent color, the settings are all over the board. The color temperature settings are... green way down low, and red and blue way up high and the color level way up high. The color is also bad with all the factory default settings. The color is OK however when receiving off the air digital broadcasts. The picture is sharp though. I just bought this yesterday and am wondering if I should take it back??? Thank you! Bob
  • wotbob01 Mar 05, 2009
    Thank you. I did some more experimenting and came up with the same results. The only thing close is off the air digital broadcasts but it still isn't right. I talked to two very experienced TV techs and they both had the idea that it may have been dropped somewhere along the line. They both said LCD's cannot be dropped. Do you agree? I will try the cable experiment you mentioned at the store because it looks like it's going back this weekend. Any other opinions are welcome. Thanks, Bob
  • 718 Answers
YES. Take it back. Also take your DVD and cables also. Have the store try the tv with their DVD and cables and see if you get the same problems. It it good, then try your cables. Or try your DVD with their cable. It's under warranty now so resolved it now. If you bought by credit card, that may have a brief warranty also.
Posted on Mar 05, 2009
42 inch vizio has picture (direct tv) but no sound. Tv is not on mute.
Did you check the RCA AV Cables? The ones with the red, white yellow?
What is the connection you have from Direct TV box to your TV. You might want to start on that.
It might probably as well related to any of the remote controls settings. Either of the Direct TV control or TV Control.
1. Check the cables
2. Check if there is any function on the Direct TV remote that will turn off the sound
3. CHeck the Vizio TV Menu Settings.
4. Try with other component such as DVD to discard the possibility of malfunctioning VIZIO Speakers.
Vizio offer a good customer service if still under warranty.
God Bless You!!
Feb 14, 2011 | Vizio VW37L 37 in. LCD HDTV
I bought an hdtv about a month ago and the color keeps going out like it gets a white looking color....i already reset my diretv box and reset the tv color settings but it keeps doing it off and on any...
There is usually at least a 90-day warranty. http://www.vizio.com/support/
Here is a link to Vizio customer support.They should be able to do something.You need to have a receipt probably.Also you will need model and serial numbers.Serial number should be on the back,maybe by the A/V inputs.If no receipt,did you register it?If you didn't,the credit card statement may help.Good luck.
Jun 28, 2010 | Vizio L37 Television
Signals to the tv from other sources and the image is P and G
Soon as though you have your wiring mixed up. Those leads, colors you describe are for Compnent Video signal....Red Green Blue. Now  the Others  are for Audio Visual signal , Yellow, Red, White... They are NOT compatable. IE: You cannot mix them. Check in your manual as to what  types of lead is needed how to wire it up..
Feb 01, 2010 | Televison & Video
How do I hook up my digtl cable and dvd to my Vp422 vizio tv
Surround Sound to 8 or 9 8 is best
DVD to HDMI 1
Direct TV to 10
If you have these connections on your peripherals, this is recommended..
May 12, 2009 | Vizio VP422 42 in. Plasma TV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips lcd flat 32 in
what cable are uusing for dvd yello thats why cant use yello on these or s video go buy hdmi cable ok or reg green blue if dvd dont have hdmi outs
Feb 09, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
Color blurry
If it is in in the menu aslo one of the main boards are defective. Contact Philips @ 1888-744-5477 and the will do the repairs in the set is under warranty if just out of warranty they will still help have your receipt.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
Small black squares appear on Vizio 37
Sounds like a digital cable issue to me. Try connecting the cable directly to the TV bypassing the cable box and I bet that the issue will be gone. If so then contact your cable provider as the box or the incomming signal may be at falt.
Apr 01, 2007 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
368 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
