Question about Sharp Audio Players & Recorders
Need parts for Sharp VZ 2500.
Hi i need parts for my sharp vz2500. i need a drive belt and the needle for the turntable, also roller for the cassette player, Can any one help me find these parts.Thank you so much.
ashrafdin@hotmail.com
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: faulty turntable
Hi Roger It will need a new turn table belt. They are an odd size, but can generally be bought from a good spares part supplier. Let me know where you are and i will be able to steer you to a parts agent that can organise one for you. Thanks for using FixYa. A "fixya" rating will help my profile and create an incentive to get the parts source organised for you;)
regards
Graeme
Posted on Mar 16, 2008
SOURCE: I have a Sharp VZ
you have to remove the front cover first. then detach the two wire connectors attached to the turntable circutry. Also detach the pushbutton pannel. remove the two screws that fix the top plastic cover inside the turtable housing. then the two big screws that fix the turntable to the main body will be visible. remove them and you can detach the turtable unit out. then remove the circuit board behind the turntable. you can then put the belt between the big disc and the motor pulley on the corner. Good luck
Posted on Oct 12, 2008
MSG-CPC
  • 1325 Answers
SOURCE: manual for Sharp VZ-3000
go to this site -- a manual is listed http://elektrotanya.com/sharp_vz-3000h_vz3000e_cpv300h_sm.pdf/download.html
please leave positive fedback for me
Posted on Oct 16, 2010
Sharp model R1380 - carousel does not work
The service manuals you need to refer to for disassembly help and proper part numbers are here and here.
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can order Sharp parts from Encompass here or call them toll-free at 866-779-5835.
Aug 22, 2010 | Sharp R-1380 Microwave Oven
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
I need a replacement turntabl drive belt for a SHARP SG-450E Hi Fi system, any idea where i can get one from please
Generic replacement belts are available from a number of suppliers, but you need to know the dimensions of the original. My cross-reference guides for a couple of companies don't list your Sharp model so I can't give you a specific part number. You might try taking the old belt to a service shop. If they have a belt gauge they might be able to order a suitable PRB brand or equivalent replacement for you.
Doing a search for your model turned up this vendor (in Australia!) who claims to have the belt in stock. They offer international shipping, so maybe this would work for you.
Good luck, and thanks for using Fixya!
Feb 03, 2010 | Audio Players & Recorders
Roller Stay for Sharp Carousel microwave oven
u can try www.partstore.com
but the tray roller is pretty much univeraql if you have problems finding it for that model alost any sharp tray roller will fit the unti
i just grabbed one out of the dump for my personal un it and it works fine
Oct 09, 2009 | Sharp KB6024MK 1000 Watts Microwave Oven
What do you call the three pronged plastic "thing" the plate sits on inside the microwave? It started on fire and I need to order a new one for a Sharp microwave model # R1420B
turntable guide with rollers...Turntable Support,  others... Here's a TN supplier: http://microwaveglasstrays.com/shop/-c-44_58.html
Jul 15, 2009 | Sharp R-510HW Microwave Oven
TURNTABLE NOT TURNING AT ALL & ALL ELSE WORKS GREAT!
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the service manuals for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Nov 28, 2008 | Sharp R-1870 Convection/Microwave Oven
I have a Sharp VZ 2500. The drive belt lies in pieces at the bottom of the player, so I can assume it needs replacing. I've bought the belt, but have no idea where it goes. Can you help?
Aug 03, 2008 | Sharp Audio Players & Recorders
Faulty turntable
regards
Graeme
Mar 15, 2008 | Audio Players & Recorders
150 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
