Nuance PDF Converter Pro 8 Windows Academic Logo
Dick Putter Posted on Apr 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Strugling to download program
I was trying to down load new nuance program, I then received a message " .net framework 4 failed to load". I then, tried to load .net framework 4 from microsoft site and got a code error "HRESULT 0xc8000222
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Apr 01, 2013
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1015225
Points
21773
Post your OS, Service Pack if applicable. Have you done ALL your Windows Updates? Take a look at this procedure: http://digita7seven.blogspot.com/2012/11/how-to-fix-error-hresult-0xc8000222-net.html
Nero 9. "this feature requires Microsoft .NET
Just download the .NET framework at Microsoft. See link
NET Framework 4 5 or search ".net download Microsoft".
Just run the downloaded upgrade program and you can use Nero 9.
However, for burning cd or dvd you can better use Imgburn, a free and powerful burning package. See: NET Framework 4 5
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
1helpful
Error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
2helpful
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
.Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from www.microsoft.com/downloads
1helpful
HP colour laserjet 1600 not recognised by USB port
I believe the problem is related to microsoft .NET Framework. I have researched and there are many posts of incompatibility between .NET Framework and many printers not just 1600. My 1600 stopped working and I traced the problem to upgrade to .NET Framework 3.5 I uninstalled 1600, then uninstalled .NET Framework 3.5 (and 3.0 as well for good measure), reinstalled 1600 and it is working fine now again. You can uninstall .NET versions using Add/Remove programs on the Control Panel. To avoid re-updating, I also turned off Windows automatic updates. I left .NET Framework 2.0. No problems with other programs but the computer did have trouble rebooting the very first time after I uninstalled .NET Framework 3.5 and 3.0. Unknown if that was related to the uninstall or a completely unrelated problem. Anyway if you want to try something less drastic than removing .NET versions, check out this Microsoft link:
http://support.microsoft.com/kb/961118
refers to a printer fix related to .NET. In my experience, the Microsoft fixes never work but you are welcome to try before uninstalling .NET Framework versions.
1helpful
2answers
Easyshere 5300
The error message appears due to a faulty dot net framework installation on the system.
Perform the below mentioned steps in order to fix the issue.
· Uninstall the Dot Net Framework 2.0 from the system from the add/remove programs section in add/remove programs if the OS is XP.
· Else you can also download the Aaron-Stebner's .Net Framework Setup Cleanup Utility from the website: http://www.raymond.cc/blog/archives/2008/12/02/uninstall-microsoft-net-framework -with-aaron-stebner-cleanup-tool/
· On this website, guide the customer click on the Hyperlink [Download .Net Framework Setup Cleanup Utility]
· Save the utility and run it. When given the list of options, choose Dot net framework 2.0.
·Follow the prompts to uninstall the .Net framework 2.0
·Restart the system.
·Download the .Net framework 2.0 from the website:
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5
· When prompted, save the file and then run it. [Don’t try to run the file without saving it; else you would get an error message
Error 0X80131107
Error Code 25015.
·After the installation of the .Net framework 2.0, check the AIO Home Center again.
Best of Luck
Saj
When i try to use hallmark studio, i get the phrase application failed to initialize properly (0x0000135)
Please run windows update. It's important that you install Microsoft .Net framework & other security fixes.
When updating .Net framework there are many, please stay in order (smallest to largest). .Net framework 1.0.
.Net framework 1.1 & so on. When your PC has completed all updates try your program; hallmark studio again. If it still fails, reinstall the program & do not run other programs during install.
If you have more questions feel free to ask.
Good Luck & Kind Regards.
.net compact framework
This is the newest .NET compact framework.
http://www.microsoft.com/downloads/details.aspx?FamilyID=e3821449-3c6b-42f1-9fd9-0041345b3385&DisplayLang=en
attach pocket pc via activesync, click download, click "start download" if necessary, and then run the downloaded application. Activesync will do the rest.
Top Nuance Computers & Internet Experts
 Grubhead
Grubhead
Larry Ng
Larry Ng
Alison Lofts
Alison Lofts
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
